tranny temp sensor - JeepForum.com
post #1 of 2 Old 05-10-2012, 08:48 AM Thread Starter
richardclarkjr
1994 XJ Cherokee
tranny temp sensor
How would i install a temp sesnsor in my xj i have the gauge ib but dont know where to instal the sensor or what i need to do so......thanks
richardclarkjr is offline
post #2 of 2 Old 05-15-2012, 03:31 PM
allmopars
just installed the b&m trans temp gauge on my 68 dart. You cut the metal trans line, install pressure fittings with plumbers tape then run your wire to gauge. The trans line to install it on would be the line out which is generally located up higher(but check) and locate it closest to trans for most accurate reading. The trans lines im refering to are the ones running to your radiator cooler.
allmopars is offline
