Trailer Sway Control Kit,do they work ?? - JeepForum.com
post #1 of 4 Old 02-27-2012, 10:48 PM Thread Starter
hdrocknroll
Saw this at Harbor Freight
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 4 Old 02-29-2012, 06:09 PM
ssjeff
Yes, they work. I have mine attached to a Weight Distribution hitch which is the best investment in a heavy trailer. It helps with side winds wipping the trailer around.
Most hitches are only rated at 500 lbs tongue weight without a WD hitch and then they go up a lot.
ssjeff is offline
post #3 of 4 Old 02-29-2012, 07:09 PM
RedNeckRanger
yes they do work for sway,they r amazing ! i use one
RedNeckRanger is offline
post #4 of 4 Old 02-29-2012, 08:07 PM Thread Starter
hdrocknroll
Thanks for the input
I also found a Curt brand at amazon for $44.00
Have Class III hatch and 3,000 max trailer,2 wheel
towing
Upper control arm brackets....control arm side, where to buy?? -XJguy- Fabrication Shop 9 03-04-2010 08:57 PM
battery died and now my cruz control does not work. remedy9 Audio, CB & Ham Radios, GPS, & Electrical 4 08-09-2009 04:29 PM
Build Trailer Using Trailer House Axles?? jsc7002 Fabrication Shop 5 07-19-2009 06:43 PM
High clearance control arms vs. Normal control arms, which is better? dail4760 General Jeep & Off-Road Equipment 1 10-17-2006 07:27 AM
Control arm bushings or replace control arms rob5059MOD Tires & Wheels 0 09-11-2006 06:30 AM
