Tow hooks from tractor supply? - JeepForum.com
post #1 of 12 Old 09-05-2006, 09:03 AM Thread Starter
jclaudii
I looked yesterday and I could not find them. What do they look like so I can take them a picture of what i want. I asked them for a mountable to hook or chain hook and they could not find one. They said they had some that welded on, but I did not even look at them.
I appreciate the help because the tow hooks are temporary until I get my jeep ones in. Thanks.
jclaudii is offline
post #2 of 12 Old 09-05-2006, 10:27 AM
battallion14
battallion14's Avatar
They look like this:
And are rated at 10,000 lbs which is a lot more than the factory tow hooks. If I were you I would go with the Tractor Supply ones and cancel your Jeep ones. I replaced my factory ones with the ones from TSC.
battallion14 is offline
post #3 of 12 Old 09-05-2006, 10:33 AM
1979CJ7
1979CJ7's Avatar
1979 CJ7
thats what i have as well. those look better and can hold more so i could stick with them
1979CJ7 is offline
post #4 of 12 Old 09-05-2006, 10:42 AM
93Renny
Just go to where they have all the tie downs and ratchet straps at. Usually they're in a display box waste high. As pictures above, they have both black and chrome.
1993 Jeep Renegade, 4.0 I6, 2.5 Rubicon Express Lift kit, 1 inch Shackles, BFG 32x11.50x15
Other add ons, TJ style Stainless hood catches, custom tow hitch......
93Renny is offline
post #5 of 12 Old 09-05-2006, 10:49 AM Thread Starter
jclaudii
I bought my tow strap there just the other day and I looked all around that area. I'll go to a different one in another town and see if they have them. I already told the guy I would give him 25 bucks here on jf I guess I could see if he would sell me the rear tow hook only. I appreciate the pictures.
What size bolt do I need becasue I know a good wholesale bolt store close to me that I can get a decent price at. Thanks alot guys!
jclaudii is offline
post #6 of 12 Old 09-05-2006, 11:07 AM
Lostj
Lostj's Avatar
if you cant find them there, try northern they have them
00'TJ
74'CJ5 For Sale
Lostj is offline
post #7 of 12 Old 09-05-2006, 08:07 PM
fried_gold
fried_gold's Avatar
I've seen the hooks in auto parts stores too.
The bolts you need are 1/2 inch grade 8 bolts 3 inches long, If you're in Tractor Supply, you can get grade-8 hardware there for about $3 per pound. You need coarse threaded bolts, but I think all of Tractor Supply's grade-8 1/2 bolts that size are coarse threaded so whatever they have should work
fried_gold is offline
post #8 of 12 Old 09-07-2006, 11:56 AM Thread Starter
jclaudii
anyone know the part number of them I'm still having trouble finding them even with a picture. maybe arkansas stores are different.
jclaudii is offline
post #9 of 12 Old 09-07-2006, 02:16 PM
UnsanePyro
Just wondering why you need coarse thread, do they thread right into something?
UnsanePyro is offline
post #10 of 12 Old 09-07-2006, 02:24 PM
mdm
Farm Wheeler
There are nuts welded onto the frame that the bolts go into.
mdm is offline
post #11 of 12 Old 09-07-2006, 08:03 PM
UnsanePyro
That's what I figured, wasn't sure though, seems like fine thread would be better, but oh well, I need to pick up a set before I go out wheeling (spring probably)
post #12 of 12 Old 09-08-2006, 07:04 AM Thread Starter
jclaudii
Found 'em!
They were $7.26 a piece here at my Tractor Supply Store in Arkansas.
The item # on the reciept is 3018133
The item name is "tow hook keeper 1000"
I picked up 4 bolts 4 lock washers and 8 machine washers all Grade 8 hardware for about 5 bucks. Bolts are 1/2 by 3 inch and I got the washers in case the non threaded part gives me problems on the bolt. All I need now is a torx bit and them babies are going on! Thansk for the help
jclaudii is offline
Tractor tires ArrizX Tires & Wheels 54 11-15-2013 10:48 AM
Where do you mount your recovery hardware? Tow hooks? Clevis hooks? jrodum General Jeep & Off-Road Equipment 9 11-12-2007 06:45 PM
Where do YOu mount your tow hooks? clevis hooks? pics jrodum General Jeep & Off-Road Equipment 2 10-01-2007 08:37 AM
tractor supply hi lift jack Bot General Jeep & Off-Road Equipment 14 03-09-2006 08:59 AM
Fixing up the old tractor RWB214 Engines & Drivetrain 1 04-24-2005 08:08 AM
