Tow hook bolts - JeepForum.com
post #1 of 12 Old 05-11-2001, 11:44 AM Thread Starter
jmsjeep
Tow hook bolts
I just put on tow hooks on the front which used exsisting holes in frame. The hooks came with bolts that did not have either grade 5 or 8 markings. Shouldn't they be?
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 12 Old 05-11-2001, 11:52 AM
JR
I don't know anything about the grades but I have the hooks that go onto the fron bumper. they are rated for 10,000lbs and let me tell you I have been pulled out of many the mud hole and they have held up with no problem. I have taken them off from time to time just to make sure there straight and there has been no problems.
just my 0.02
95 yj 4.0 3" lift/ 31 geolander muds
JR is offline
post #3 of 12 Old 05-11-2001, 12:09 PM
cjjody
If the bolts really bug you, it's probably good insurance to head to the local hardware store, shell out an extra $4 for some grade 5 bolts. Stay away from the grade 8 for the tow hooks, they are too brittle for stuff like this. The grade 5 will give a little when you start yanking stuck Toyota's out-o-the-mud.
'63 CJ-5
Chevy 400, TH350, Spicer18
31x10.5x15's PS, PB
cjjody is offline
post #4 of 12 Old 05-15-2001, 09:33 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Ya, I agree .. I just replaced my bolts on my front tow-hooks with some new ones .. cost a couple bux and I got Grade-5 strength .. it might bend, but rarely break. Grade-8 is very strong, but it will break before it bends.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 12 Old 06-30-2001, 11:40 AM
-D-
What's the exact size on those bolts that mount into the thread holes on a '95 YJ? I think it's 7/16" x 2 3/4" SAE thread but I can't be sure. Also I checked both auto and hardware stores around the area and couldn't find the above size in grade 8, anywhere else I can get them from?
-D-
-D- is offline
post #6 of 12 Old 07-01-2001, 11:28 PM
-D-
Nevermind my last post, I found out that I have been an idiot the whole time. I took the first bolt out of the package and assumed that since it didn't fit the rest wouldn't either. It turns out that the Steelhorse Tow Hook kit comes with 2 sets of bolts and nuts for various differnt rigs, one set fits into YJ model Jeeps. I installed them today and they look great.
-D-
-D- is offline
post #7 of 12 Old 07-02-2001, 03:29 AM
Tonka
2015 JK Wrangler
Steel Horse!?! Every thing that I have seen from that company is junk, except for a few soft tops
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #8 of 12 Old 07-02-2001, 02:05 PM
-D-
Well, I said they look great, no mention of their um.. performance (haven't had a need or a chance to use them). How would I go about testing if they were good or not? I don't have 10k lb of drag to pull around. They were the only brand of tow hooks that the local 4WD store had for YJ's.
-D- is offline
post #9 of 12 Old 07-02-2001, 04:05 PM Thread Starter
jmsjeep
Mine are also steel horse, ARE THEY SAFE?
I've pulled some trees with them, but haven't pulled vehicle yet.
jmsjeep is offline
post #10 of 12 Old 07-05-2001, 10:41 AM
Angell
I wouldn't worry about things like tow-hooks made by Steel Horse. It's kinda hard to mess up a tow-hook. It's a hunk of metal, ya' know?
Angell is offline
post #11 of 12 Old 07-10-2001, 11:43 PM
osburn
osburn's Avatar
You've obviously never seen a tow hook fail. I've seen one bent almost straight. I dunno what brand it was, and I don't know if Steal Whores is worth a damn. But me, I wouldn't touch anything from Steal Whores.
Matt Osburn
Score 1032
osburn is offline
post #12 of 12 Old 07-15-2001, 07:26 PM
NaeKid
NaeKid's Avatar
A buddy used the stock tow-hooks on his TJ and not only bent the hook straight but 1/2 twisted it out as well. Mind you .. he was trying to drag a 3/4ton Chevy that was buried in mud runnin' on 40" tires .. but still .. one hook bent out.
I picked up some generic 10,000lb hooks from a farm supply store here in Calgary (Princess Auto) .. as strong as could be and cheap like borcht.
I also have heard both good and bad about Steel Horse ... stress products don't seem to standup, but the non-high-stress products are good.
Currently I have their GrabHandles and rearbumper with tire carrier. The tire carrier rattles like a paint can all the time, so I think I might re-design a new one in my spare time.
Silver
NaeKid is offline
Amp hook up Maroon03TJ Audio, CB & Ham Radios, GPS, & Electrical 6 05-19-2009 09:37 PM
Where can I hook my PCV??????? Calebster Engines & Drivetrain 0 11-23-2008 08:07 PM
Is this hook acceptable to use for a recovery hook? Deserthiker General Jeep & Off-Road Equipment 8 07-14-2008 02:36 PM
Tow Hook BC-KC 4000 Engines & Drivetrain 7 01-20-2007 08:57 AM
SUB HOOK UP? jerrys yj Audio, CB & Ham Radios, GPS, & Electrical 3 01-23-2002 06:14 PM
