Tool for flushing brakes - JeepForum.com
post #1 of 6 Old 05-10-2013, 03:37 PM Thread Starter
dubnutty
Anyone purchase one of those Motive pressure bleeders? Need to get the brakes flushed on my 06 Rubi. Which model did you purchase and from whom. I've been looking at ones on Amazon and have been getting kinda confused on different models. Some people's review say they leak but maybe they didnt use the correct adaptor. I have some other cars I need to do so purchasing one is going to be a for sure thing. Any opinions would be very helpful.
dubnutty is offline
post #2 of 6 Old 05-13-2013, 09:25 AM
RowJ
I prefer Speed Bleeders and flush the system by refilling master cylinder as I drain it.
Cheaper and easier, IMO.
RowJ is offline
post #3 of 6 Old 05-15-2013, 11:52 AM
GilaMtnJeep
GilaMtnJeep's Avatar
This^^
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #4 of 6 Old 05-15-2013, 02:40 PM
TSEJEEPERS
You can just gravity bleed them.
Open the bleeders, attach a plastic hose and run it into a can.
Keep the master full. When you see clear fluid come out you are done.
Never done it on a ABS vehicle but I see no reason it would not work.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #5 of 6 Old 05-16-2013, 06:29 AM
RowJ
Never tried that.... without pumping the brake pedal?? Isn't it VERY slow?
RJ
RowJ is offline
post #6 of 6 Old 05-16-2013, 11:34 PM
74Maverick
Are you talking about a bleeder ball, that you attach to the master cylinder lid and pump on? If so they work great if you have the right fitting for your vehicle. But honestly they arent neccesary. Also why are you flushing your lines did you get water in them? If not your talking about bleeding them. Which if you install speed bleeder valves is incredibly easy. If your putting on a new master cylinder there is another method for that which uses a kit that usually comes with it in the box.
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
