Quantcast TJ tailgate need a answer fast - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > TJ tailgate need a answer fast
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 04-29-2008, 10:25 AM   #1
wick913
Just need to know if a tailgate from 98 tj will fit a 2004 rubicon???? Found one for on the cheap!!!! Wont do me any good if it wont fit... Thanks
wick913 is offline   Reply With Quote
Old 04-29-2008, 10:43 PM   #2
goatboy
Probably...they are both TJ's...if it's cheap enough, throw the dice and buy it.
goatboy is offline   Reply With Quote
Old 05-01-2008, 01:44 AM   #3
edmond
I would say yes, they are the same, should not have any issues, I know for a fact that the hinges are interchangable.
2006 LJ, 38" BFG's on KMC Beadlocks, Sway-A-Way coilovers, FT LA, D60 ProRocks,ARB's,Rock Hard Cage, Prestige Billet Products Etc..
edmond is offline   Reply With Quote
Old 05-01-2008, 06:52 AM   #4
goatboy
Well, what did you end up doin'?
Old 05-02-2008, 09:44 PM   #5
wick913
heck yes got it for ten dollars. Will let you know if it works once i get it.
Old 05-03-2008, 01:06 AM   #6
Crashnburn80
The difference is that the 98 tailgate doesnt have vents, the 04 does. The vents were moved from the hardtop in the 98 to the tailgate in 04. So if you run an 04 (no vent) hardtop with a no-vent tailgate you will just notice a little more pressure difference when you shut your door ect.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 05-06-2008, 08:46 AM   #7
wick913
Thanks for all the info you all have provided to me!! Still waiting on the tailgate but will let you know how it goes If anyone is iterested..
Old 05-13-2008, 12:37 AM   #8
wick913
Hey if anybody is concered. The tailgate did work fine, with a little boring on the lock hole, i was even able to keep my back door lock. One thing i did notice, they used all metal in 98 and my04 had alot of plastic. Guess metal is to expensive now.
Glock Forum
