Tj liftkit? - JeepForum.com
post #1 of 4 Old 05-15-2011, 12:59 PM Thread Starter
Emt465
Tj liftkit?
What is the cheapest and easiest way for me to lift my tj? I've heard a lot about the budget lift. If I do that do I have to put new struts on at the same time. Any advice would be great.
Emt465 is offline
post #2 of 4 Old 05-15-2011, 08:58 PM
RogueSpear2023
Well you jeep doesn't have struts so thats going to be kind of hard. Search budget boost or BB that should give you a good idea of what you are looking at. If you want to go up 1" or more you will need new shocks as the the stock ones are not long enough.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #3 of 4 Old 05-17-2011, 01:46 PM
cr1193
look in the TJ tech forum, plenty of info on this subject.....
cr1193 is offline
post #4 of 4 Old 05-17-2011, 03:57 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
Also depends on what you plan on doing with your Jeep, and how large a tire you're wanting to go to. A 1-2" lift with 31" tires can be done pretty cheaply, but it gets more complicated the higher you go because there's more stuff involved/issues to be addressed. Like someone else mentioned, look in the TJ tech forum. Also talk to others that have lifted Jeeps. Most Jeepers are more than happy to answer your questions if you go up to them and ask them questions related to their Jeep. Is there a Jeep club in your area?
It sounds like you're new to Jeeps. Welcome! You might want to pick up an issue of JP magazine, 4WD & Sport Utility magazine (and subscribe to them), and google "Quadratec" and order a catalog - that'll get you started. Do a lot of research and ask a lot of questions before you start spending money on your Jeep. It's best if you only have to spend money once.
Since you didn't fill out your profile yet, we don't know anything about your Jeep how old your Jeep is. A budget boost is basically just a spring spacer that goes on top of your current springs. If you're running factory springs, and your Jeep is a bit older or has a lot of miles on it, you'd be putting spacers on top of possibly tired springs. A mild lift kit with new springs isn't that much more than a budget boost lift. Something to think about...
armyRN is offline
