Thunk, I don't know where else to look... - JeepForum.com
post #1 of 3 Old 09-25-2017, 04:43 PM Thread Starter
Ravenbar
'02 WJ 4.0 42re nv242
Posting this in general to get the most responses.
For as long as I can remember I've sometimes had a thunk when I slow down/stop, crest a hill, let off gas quickly at moderate speed(sub-40mph), Doesn't seem to happen at high speed. When it happens I feel the Jeep jerk ahead like I'm getting rear ended. It seems to be torque related in that if I'm at the top of a gear(high RPM), it happens worst but if I accelerate a little and the trans downshifts(lower RPM), It barely happens if at all.
What I've already replaced:
-rear upper control arm & balljoint(body bushings were bad)
-shocks/springs(2" lift)
-transmission(had slippage)
-transfer case(grinding noise if I went over 30mph in full time 4wd)
-rear ujoints
-front upper left control arm, all other front control arms removed & inspected)
-TRE's, balljoints, steering box, sway bar links
-Rear diff spider gears(shaft wear & excessive backlash) (this was my last ditch effort and I have nowhere else to look, ring & pinion have little backlash.)
-Greases slipyoke repeatedly.
-Pryed on rear lower control arms & don't find any excess movement.
Saturday I replaced the spider gears & the issue went away for the 100ish miles I drove yesterday, broken up into 3 sections with cooldown time between to break in the gears. Headed into work this morning, it came back & the longer I drove, the worse it got, now it's back to where it started.
Suggestions I've gotten:
-Carrier bearings
-Just the nature of the beast
Project Thumper:
Member of Fourth Coast Jeeps
Ravenbar is offline
post #2 of 3 Old 09-26-2017, 05:27 AM
wilson1010
Motor mounts on that list?
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #3 of 3 Old 09-26-2017, 01:17 PM Thread Starter
Ravenbar
Haven't replaced them but they look good.
It seems to be a movement parallel to the vehicles travel rather than side to side as I'd expect from motor mounts. It also seems to be relative to vehicle inclination. It happens worse going downhill & not at all going up hill.
Project Thumper:
Ravenbar is offline
