Thread Size, Radiator T-Stat - JeepForum.com
post #1 of 2 Old 06-29-2013, 11:51 PM Thread Starter
88comanche
1988 MJ Comanche
88 4.0l Commanche (MJ/XJ) has an electric t-stat in driver side end of radiator, what are the specs on thread for this??
88comanche is offline
post #2 of 2 Old 06-30-2013, 01:16 AM
5-90
5-90's Avatar
1988 XJ Cherokee
If you're talking about the Thermal Fan Switch in the driver's side radiator tank (sounds like it - two wires, about a 1" hex?) then the threads should be M20-1.5.
If you need to know to merely plug the hole after doing some conversion or other, you can just leave that plug in place and clip the wiring off. If you're doing something else, ask away and we'll see what else we can come up with for you!
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
