Think i need a heater core - JeepForum.com
post #1 of 4 Old 02-04-2014, 03:36 PM Thread Starter
Blakehenry96
I got a WJ and I can control which I direction I want the air to blow but cold. I can put it on high it would still be cold. It blows hard just not hot air
Blakehenry96 is offline
post #2 of 4 Old 02-04-2014, 03:47 PM
1320yj
I may be speaking out of turn here but a WJ is a Grand Cherokee if I am correct. The Grand Cherokee heater is controlled by an electric motor that moves the blend door . The dash control or the motor could be the problem this can be fixed without pulling the dash.However if you have a plugged heater core or a broken blend door inside the case the dash will have to come out. BIG BUCKS
1995 2.5 5 Speed SOA +2.5 rough Country lift, High steer kit , 33x12.50 Mud Rovers
1320yj is offline
post #3 of 4 Old 02-04-2014, 05:40 PM Thread Starter
Blakehenry96
a WJ Is a 99-04 grand cherokee so is that where it was found?
post #4 of 4 Old 02-04-2014, 07:47 PM
1320yj
Its been a while but as i remember the temp control motor is mounted to the bottom or left side of the evap case, It will have a plug with multiple wires in it.I would have to dig up one of my old A/C manuals to be more specific.
1320yj is offline
