Tent trailer lift kit - JeepForum.com
post #1 of 6 Old 05-18-2009, 08:43 AM Thread Starter
Bushwalker22
I have found a few threads on lifted pop-up tent trailers, but I am just wanting some info on the process. I have an 03 Coleman utah with spring under axle suspension. My WJ is lifted 5" with 33's and I want to lift my pup so I don't rip anything off the backend as it sits pretty low. I know I can buy a larger drop hitch but I want to do a spring over on this to gain ground clearance. I have read that I should and should not flip the axle as these are set for camber and all that already? Is this true should I just pull the springs and drop the axle then bolt back together or should I flip the axle? Thanks for all your help in advance
Bushwalker22 is offline
post #2 of 6 Old 05-18-2009, 10:46 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
You generally cannot flip the axle, for the reason you stated. This site will provide you with hours of reading: http://www.mikenchell.com/forums/vie...3d2e9dd22ee585
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #3 of 6 Old 05-18-2009, 09:00 PM
Burlbook48
Trial By Trail
Burlbook48's Avatar
The "axle flip" isn't really an axle flip at all. It's just a common name for a kit that you buy which places a SOA spring perch on the top of the axle and bolts to the original SUA spring perch. You have to be careful to keep the new perch exactly parallel to the original perch when you set it up, as these Dexter axles have a set to them, and rotating the axle will throw the tires out of alignment causing premature tire wear. It's also advised to at least tack-weld the new perches in place once they are set up correctly. It's one of the best mods I've done to our '98 Utah (pretty much the same floorplan as the later Bayside: slide-out dining, couch, double king beds, sleeps nine, yadda, yadda). For more info than you'd care to ever read on this and other modifications to a pop-up trailer, check out any of the Pop-Up Camper forums. But it really is that simple--- drop the springs, unbolt the axle, install the new perch, and bolt back together. Be careful though, starting to modify a pop-up is as slippery a slope as modifying a jeep. There's a LOT of things you can do to those trailers to make them more suitable for your needs.
Be advised, lifting the trailer will also mean your stabilizer jacks may not reach the ground on an uneven camp site, and your tongue jack may need to be upgraded to a larger size. The door step will also be higher from the ground. But, you can easily switch to a 14" trailer tire (available almost anywhere, and with a higher load rating), instead of using those damnable 13" Duro tires that are almost impossible to find if you need one on the road.
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #4 of 6 Old 05-19-2009, 08:50 AM Thread Starter
Bushwalker22
Thanks for the information Guys, Very Helpful. Can I pick up the spring perches anywhere or do I need to get one specific for my trailer? There is a company here that specializes in suspension work called Spec-trac, I should be able to get the perches from them right?
Thanks Again
post #5 of 6 Old 05-19-2009, 11:29 AM
mecompco
mecompco's Avatar
1994 XJ Cherokee
I think they are pretty generic. If you can't find them locally, http://abctrailerparts.com/ has some pretty good prices.
mecompco is offline
post #6 of 6 Old 05-19-2009, 01:02 PM Thread Starter
Bushwalker22
Got them locally, Tackle this project tomorrow. Thanks for all the help guys. I really appreciate it
roof top tent onlyjeepin' Fabrication Shop 26 10-29-2013 08:35 PM
Offroad tent trailer design. Improvements? Madmanmiller802 Fabrication Shop 8 09-09-2009 04:55 PM
Build Trailer Using Trailer House Axles?? jsc7002 Fabrication Shop 5 07-19-2009 07:43 PM
Thinking about a SOA for my tent trailer Jerry Bransford Fabrication Shop 15 12-22-2007 11:05 AM
Roof top tent New in box Manny50 General Jeep & Off-Road Equipment 0 09-06-2006 05:34 PM
