Synthetic winch cable care - JeepForum.com
 4Likes
  • 3 Post By Jerry Bransford
  • 1 Post By Knuckelhead
post #1 of 5 Old 04-15-2017, 04:28 PM Thread Starter
kadehamilton
Got a new synthetic cable from TSC for a heck of a deal! Anyways I've researched about washing it out and cleaning, but what about storage? And when I say storage when it's on my winch do I keep it taunt or a little loose??
Sent from my iPhone using Tapatalk
kadehamilton is offline
post #2 of 5 Old 04-15-2017, 05:53 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Synthetic ropes for winches are protected by a UV coating so even though a cover wouldn't be a bad idea, it's not required. And winch lines should be stored taut and as tight as recommended by the winch manufacturer. A typical load of around 250 lbs. is recommended when spooling the line onto the winch. I pull my rope out and connect it to something like another Jeep. Then I put my Jeep in neutral, pull up my Jeep's parking brake a few clicks to give the necessary load, then use the remote control to winch my Jeep forward to the other jeep while carefully guiding the rope onto the drum so it lays on it evenly with each wrap next to the proceeding wrap.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #3 of 5 Old 04-15-2017, 05:57 PM Thread Starter
kadehamilton
That's how I spoiled it up on there. Thanks Jerry!
post #4 of 5 Old 04-15-2017, 08:56 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Happy winch:
I seem to remember a thread long ago about putting the rope in a washing machine to clean it?...
kadehamilton likes this.
Knuckelhead is offline
post #5 of 5 Old 04-16-2017, 06:38 AM
wilson1010
Galvanized cable suffers from being dirty because the dirt absorbs the moisture and increases rust.
A dirty synthetic cable could be harmed by friction caused by dirt - if one was spooling it in and out a couple hundred times a year. Other than that, it is a bad idea to wash synthetic cable because the finishes are on the surface of the Dyneema not impregnated into the polyester.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
