Suspension Travel - JeepForum.com
post #1 of 6 Old 02-11-2014, 03:54 PM Thread Starter
goodtago
Suspension Travel
Hey there, I'm new to this forum, and also new to owning a Jeep TJ. I have bought a 2003 Jeep TJ sport, with a 2.5" rough country spring lift kit in it. The rear shocks are no good anymore, and I have ordered new ones. The ones I ordered are 21.5" Extended, and 13.5" collapsed. When the Jeep is at a stand still the shocks are 15.5" Eye to Eye. I guess what I need to ask, is 2" enough up-travel for every day driving around town and highway? I will do some offroading, but for the most part it will be around town. OR do I need to get shorter shocks, so that the up and down travel are close to equal? Please help me understand this. Thank you in advance
-Jerry
goodtago is offline
post #2 of 6 Old 02-11-2014, 05:42 PM
tjcj
More than likely the 2" will not be enough up travel.
Yakima Valley Mountaineers.
tjcj is offline
post #3 of 6 Old 02-11-2014, 06:26 PM
222Doc
222Doc's Avatar
how much space is the rear bumps. you do not want the shock to become the bump stop.
222Doc is offline
post #4 of 6 Old 02-11-2014, 08:10 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2" is not enough uptravel.
You want at least 4" for a comfortable ride around town.
Do you still have 2.5" of lift from the RC springs? Sounds like they may have sagged a little. If you measure the rear springs with the Jeep sitting at ride height, do they measure around 10.5"?
Wheelin98TJ is offline
post #5 of 6 Old 02-12-2014, 03:07 PM Thread Starter
goodtago
Originally Posted by Wheelin98TJ
2" is not enough uptravel. You want at least 4" for a comfortable ride around town. Do you still have 2.5" of lift from the RC springs? Sounds like they may have sagged a little. If you measure the rear springs with the Jeep sitting at ride height, do they measure around 10.5"?
I measured the rear spring and it is only sitting about 9.75". Because if this should I try for shorter springs to get more up travel? The bumps have way too long of a gap, they're measuring roughly 6". Any thoughts from here? The shocks I have ordered, and only 2" of up travel, are bilstein and have total travel of 8". The next size smaller only have 6" of travel. If I put the smaller ones in, then I would have more up travel, but not as much down travel. Thanks for all of the help this far!!
goodtago is offline
post #6 of 6 Old 02-12-2014, 03:58 PM
Wheelin98TJ
JEEP FREAK
Shorter springs will give you less room for uptravel.
Your bumpstops need extended. It sounds like they were left alone when the lift was put on.
