Quantcast superflow mv50 still the way to go? - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > superflow mv50 still the way to go?
Old 05-28-2008, 05:43 PM   #16
BlackBellamy
Originally Posted by vegasjeepguy View Post
Used mine this weekend aired up 8 tires from 15psi to 32 psi in about 15 minutes.
Yup, I was over at Rausch Creek this past Sunday and I aired up myself and a buddy from the club without any overheating or rest - I don't know how long it took because who counts minutes at the end of a long day of wheeling. It wasn't long enough to comment about it.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline   Reply With Quote
Old 05-28-2008, 07:48 PM   #17
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Originally Posted by pipelineaudio View Post
Is this one any good?
http://www.partsamerica.com/productdetail.aspx?MfrCode=SLM&MfrPartNumber=COMP0 6&CategoryCode=3185
It goes into the cig lighter, so Im thinking it cant draw that much
You are right in your thinking that it's crap. The reason the MV-50 or also called MF-1050 is that it draws about 30 amps, and has to be hooked up directly to the battery. That's why it is so fast. Mine's been going strong for 2 years now.
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote
Old 05-29-2008, 10:52 PM   #18
MuDD OlllllllO
I've had mine since last summer and it is still going strong. I installed it under the hood, hardwired to the battery, and left it there all winter (colorado) no problems at all whatsoever. It is a little tank.
2004 TJ Sahara Dana 44 Black Dual Tops w/Tinted Windows
Full Traction 3" Lift w/ M-Force Monotube Shocks
Superwinch EPi9.0 w/ Viking Synthetic Trail Line
33" Goodyear Wrangler MT/Rs, Spidertrax 1.25" Wheel Spacers
Rubicon Rocker Guards, MasterFlow OBA
MuDD OlllllllO is offline   Reply With Quote
Old 05-29-2008, 10:58 PM   #19
default_user
It's a Roobicon
thread resurrection...6 months later and no complaints
default_user is offline   Reply With Quote
Old 05-30-2008, 09:17 PM   #20
JeepinSoldier
I have to be the sole dissenter.....
I had mine for about a year and it was OK for a cheap compressor - got the job done for 33" tires but was kind of slow.
It bit the dust at an event and I got left hanging with no air when the local gas station's compressor was down as well. I had to drive a good distance on 12 PSI.
Made it a point to research OBA systems and got a PowerTank CO 2.
2005 Bright Silver Jeep Wrangler Unlimited Rubicon. Dual tops. 1990 Jeep Comanche 4x4
Bright Silver Metallic Clear Coat Exterior Paint Club Member # 307 EN
www.beltwayjeepers.com
JeepinSoldier is offline   Reply With Quote
Glock Forum
