Superflow MV-50 vs Harbor Freight's 93186 "12V High Volume Compressor" test results - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Superflow MV-50 vs Harbor Freight's 93186 "12V High Volume Compressor" test results
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 11-11-2006, 03:15 PM   #1
Hip2u77
Superflow MV50 vs Harbor Freight's 93186 "12V High Volume Compressor" test results
Superflow MV50
Maximum Volts: 12-13.8
Maximum Amps: 30a
Maximum Air Flow: 72 Liters per minute
120 PSI maximum.
Continuous use: 40 Minutes maximum
vs.
Harbor Freight's "High Volume Compressor" Model 93186.
Maximum Volts: 12V
Maximum Amps: 30a
150 PSI maximum.
Maximum Flow Rate: 2.54 CFM
Air Output: 1.35 CFM @ 40 PSI, 1.05 CFM @ 90 PSI
Continuous use: 40 Minutes maximum.
Tested them on our '07 Unlimited Rubicon's 32's. (255/75/17)
Both were brand new and ran for 30 seconds with no load to make sure they sounded ok. Both were run off the battery as designed, with the Jeep running, and both had their factory air filters installed.
I decided that it was better to just test them both for a set amount of time rather than how long it takes to fill a tire as most people have different sized tires. I lowered the air in both front tires then tested the Superflow on the front right, and the Harbor Freight on the front left. (Back to back, not together.) The Jeep had been sitting for 5 hours in a 65 degree garage before the test. Moved it outside for the tests. The temperature was 47 degrees.
I used two digital gauges and one analog to verify the results. (Neither gauge on the compressors read the correct PSI. The Harbor Freight one was off by 1 PSI and the Superflow by 5 PSI.
Start pressure 19 psi (Was supposed to be 20, but I goofed.)
Two minute clock time:
Superflow = 37 PSI
Harbor Freight = 32 PSI (It took another 30+ seconds to get to 37.)
So there you have it. The Superflow is the faster compressor. (And it just sounds like it's faster and of a better quality. Really solid sounding unit.)
Hip
Hip2u77 is offline   Reply With Quote Quick reply to this message
Unread 11-11-2006, 09:11 PM   #2
Grubbi
Glad to hear this, I bought one of the MV50's today at Pep Boys. Actually there part number is MF-1050 as someone mentioned in the other thread.
It was only $60, so not too bad.
'99 TJ 4.0, 3" Rusty's Lift, 1" Tera Body Lift, 33"s on Cragar Soft 8's
Warn XD9000i
My Jeep
Terrain Stompers Jeep Club Cincinnati, Ohio
Grubbi is offline   Reply With Quote Quick reply to this message
