Stubborn Torx Bolt on Cage - JeepForum.com
post #1 of 2 Old 04-03-2008, 03:21 PM Thread Starter
Field88
OR Fab has a 'nice' bolt-on sport cage for the cab, sure, but in the process of installing it I ended up breaking a torx bolt...sort of...on the windshield mount where the stock bars join the central roll cage with the 2 torx bolts that bolt into the winshield.
The head is not stripped, and it swivels around loosely, but it cannot, I mean CANNOT seem to be wrenched out of the hole. When I reverse it out of the hole, the thread seems to catch on something, get stuck, and then go loose again. I tried to pry on it upwards with a flathead screwdriver while reversing it, but that failed. Should I drill it out? I mean, should I hold a vice clamp on it and drill it out? Will that work? Or is there something I don't know?
Thanks.
Field88 is offline
post #2 of 2 Old 04-04-2008, 08:46 AM
rubiweeler
It sounds like you need to use an easy out on it.
But you have to watch out with those because they either work, or break off in the bolt which leaves a nice harded chunk of steel that is practically impossible to drill through.
Superior axles doesn't honor their warranty. Don't buy from them.
rubiweeler is offline
How do I removed a bolt with a stripped torx head? Fargo General Jeep & Off-Road Equipment 11 07-16-2008 11:17 AM
Help!: Stubborn Torx Bolt in ORF Cage Field88 Fabrication Shop 1 04-04-2008 01:02 PM
Stubborn Solenoids Grand Fan 4eva General Jeep & Off-Road Equipment 7 11-28-2007 05:58 AM
Removing stubborn torx screw on door hinge xltj General Jeep & Off-Road Equipment 13 09-24-2007 02:12 PM
getting out a Torx bolt bigj1974 General Jeep & Off-Road Equipment 5 08-09-2007 09:42 PM
