stock tires - JeepForum.com
post #1 of 6 Old 05-07-2011, 01:27 AM Thread Starter
devinci
stock tires
Hey guys,
Should I be airing down with stock sized tires when I go off-roading? This weekend I'll be mainly on rocky trails with the occasional muddy spot but nothing too rough.
Keep in mind my WJ is still at stock height as well.
On-road i run them at 33psi.
Any suggestions?
Thanks
devinci is offline
post #2 of 6 Old 05-07-2011, 07:41 AM
Holm-z
Holm-z's Avatar
Airing down will give you better grip on rocks and obstacles.. I recommend it. I think if you aired down you will probably lose about an inch or so of clearance depending on how low you drop your psi.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #3 of 6 Old 05-07-2011, 09:04 PM Thread Starter
devinci
That's what I was debating. There are already a few spots where I scrape on this trail so the extra gc might help.
Is there more of a risk of puncturing a tire if I left them at road pressure?
devinci is offline
post #4 of 6 Old 05-07-2011, 10:46 PM
92 Green YJ
92 Green YJ's Avatar
you may be more likely to puncture at street pressures as the tires wont flex around the rocks as much as they will aired down. Id go down to maybe 20PSI as a starting point and see how it goes, you can always take more out or put more in.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #5 of 6 Old 05-08-2011, 07:10 AM
Holm-z
Holm-z's Avatar
I wheeled many times before without airing down and never popped a tire, its all about being careful and picking good lines. I have noticed that it does make a big difference though if you air down, I was amazed at how much more grip I felt on the trail. I bought a small portable compressor that plugs into the cigarette outlet for filling back up after the trail.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #6 of 6 Old 05-09-2011, 08:22 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Definitely air down. On all-terrains with no beadlocks, I think 15-20 psi is about right to give you some resistance to blowing the bead and not compromise your ride height too far. Not only will it help your level of grip, but also level of comfort off-road. A tire at 15psi absorbs a lot more of the impact from every single bump. If I might make a recommendation, the MV-50/MF-1050 air compressor (usually $60 or so) is an excellent budget compressor that will refill your tires in about 2 minutes each when you are done for the day. It draws 30 amps and connects straight to the battery with spring clamps.
~Richard
billzcat1 is offline
off road , pressure , psi , tires
Stock 17" tires versus stock 16" tires on JK 2010Wrangler Tires & Wheels 1 04-27-2010 05:30 PM
94 Jeep Cherokee Sport, stock rims winter tires Is smaller then stock an issue? brahm Tires & Wheels 6 01-07-2009 02:31 PM
Upgrading XJ tires with other stock jeep tires pantherchams Tires & Wheels 1 11-29-2007 11:30 PM
Stock B/S w/ 12.50 Tires rjt36 Tires & Wheels 5 09-05-2006 12:24 PM
new tires on stock 04 tj shmrockosu17 Tires & Wheels 5 11-25-2004 01:23 PM
