State by State Vehicle Equipment Laws - Page 9 - JeepForum.com
post #121 of 140 Old 02-06-2011, 12:20 AM
tgrads3
2005 WK
For Massachusetts, your car cant be 2 inches taller or shorter from when it was sold by the manufacture. Also the car can not exceed 10,000lbs.
tgrads3 is offline
post #122 of 140 Old 02-06-2011, 10:06 AM
Grt_Ape
Originally Posted by jeepster2 View Post
California says no smog on vehicles 1975 and older. I have a 1978. On what year will I no longer need a smog certificate? At that time can I remove all smog equipment and/or drop in a different motor?
Basically, the State will not inspect any vehicle for 1975 or older. 1965 or older vehicles were considered "uncontrolled" vehicles, meaning there were no smog equipment requirements (one of the reasons a '65 Mustang is more desirable in CA than any other 60's model). Even with the inspection exemption for 1975 or older, it is still considered illegal to modify or alter the OEM smog equipment in any way. That doesn't stop people from doing so...just hope you don't get caught. (I had a '67 289c Mustang that I removed the smog pump and air injectors into the heads. Did it to remove the parasitic drag off the engine. Never needed an inspection, so The Man was none the wiser. Put it back on to obtain a certificate when I sold her)
http://dmv.ca.gov/vr/smogfaq.htm
Legally, if you own a 1966 or newer gasoline-powered vehicle, you cannot remove the OEM smog equipment. If you drop in a different motor, it must be of the same year or newer than the vehicle, and must have the OEM smog equipment functioning.
http://www.ehow.com/list_7168251_california-engine-swap-laws.html
Best of luck. CA smog rules suck arse if you like to modify from stock.
Chris
2006 LJ Rubicon
Grt_Ape is offline
post #123 of 140 Old 04-06-2011, 09:10 PM
Lucky313
i might've missed it, but do you know anything about regulations on fenders in New Jersey, or is there a link you can send me? i wanna make sure i'm not gonna get pulled over for cutting my fenders haha
'95 Yj Rio Grande - 4 cyl., Rough Country 2.5" lift, 33x12.5R15 Cooper Discoverer STTs, 2 KC 6" Apollo Long Rang lights, 2 KC lights, Herculiner interior, etc.
Demain N'est Jamais Promis
- Lucky13 -
Quoted from
: "When I die I hope my wife doesnt sell my toys for what I told her I paid for them"
Originally Posted by XJAbuzer View Post
My girlfriend asked me how fast it would go. I replied with "Not fast enough......to get it to the junkyard."
Originally Posted by Joe203 View Post
You know you own a YJ when nothing goes as planned.:D
Lucky313 is offline
post #124 of 140 Old 12-18-2011, 07:20 PM
izackary
I thought MA had a goofy formula involving wheelbase and track to calculate your max lift...?
izackary is offline
post #125 of 140 Old 01-08-2012, 09:41 AM
pderr676
2011 JK Wrangler
Idaho link broken
the Idaho link is broken. Here it is.
http://www.legislature.idaho.gov/ids...e49/T49CH9.htm
pderr676 is offline
post #126 of 140 Old 04-06-2012, 07:21 PM
OrphanAnnie
I'll def be checking out VA!
OrphanAnnie is offline
post #127 of 140 Old 07-02-2012, 09:18 PM
AlabamaSlamma
Alabama mirror law
ALA CODE 32-5-214 : Alabama Code - Section 32-5-214: MIRRORS
Search by Keyword or Citation
Every motor vehicle, operated singly or when towing any other vehicle, shall be equipped with a mirror so located as to reflect to the driver a view of the highway for a distance of at least 200 feet to the rear of such motor vehicle.
AlabamaSlamma is offline
post #128 of 140 Old 02-15-2013, 04:26 AM
DeltaForceB85
2011 KK Liberty
Louisiana traffic code is Title 32 found here:
http://www.legis.la.gov/legis/Laws_T...5&level=Parent
Statutes pertaining to jeeps (modded jeeps in particular):
Headlamps on motor vehicles; motorcycles and motordriven cycles
RS 32:317
Spotlights and auxiliary lamps
RS 32:320
Additional lighting equipment
RS 32:380
Width; projecting loads on vehicles
RS 32:381
Height
RS 32:364
Fenders and mudguards
RS 32:356
Windshields must be equipped with wiping and washing systems
RS 32:357
Windshields required
RS 32:352
Mufflers; requirements; prevention of excessive noise, fumes
-Josh
DeltaForceB85 is offline
post #129 of 140 Old 03-22-2013, 04:39 PM
okash
http://www.lexisnexis.com/hottopics/tncode is the place for TN Vehicle laws. Just had to look them up since I'm moving there soon. TITLE 55.
okash is offline
post #130 of 140 Old 05-03-2013, 09:17 PM
milresq
Texas
Just looked up Texas Transportation codes as of 03 May 2013. Good luck reading them all. http://www.statutes.legis.state.tx.u...htm/TN.547.htm
You can start hear at headlamps. Sec. 547.321.
height from 24 to 54 inches.
Todd J. Kennedy
United States Navy
Ret. HOOYAH
2002 WJOE Stocker
milresq is offline
post #131 of 140 Old 05-12-2013, 09:34 PM
DpDave
http://www.leg.state.fl.us/Statutes/...EChapter%20316
Would appear to be the latest in Florida state stautes... As the last poster said, good luck!
If yer gonna fight, fight like the third monkey on the ramp to Noah's Ark.
My Build Thread:
DpDave is offline
post #132 of 140 Old 05-13-2013, 04:53 PM
tucsonzj
they do, but it's whichever is greater if I remember correctly. Kind of one of those laws not really enforced, but could fail inspection due to this.
I'm still trying to find MA laws on no bumper cover.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #133 of 140 Old 06-06-2013, 03:29 PM
icbm99
So far I've found the following for Alaska:
http://doa.alaska.gov/dmv/faq/regs.htm
http://www.legis.state.ak.us/basis/folioproxy.asp?url=http://wwwjnu01.legis.state.ak.us/cgi-bin/folioisa.dll/aac/query=[JUMP:'Title13Chap04']/doc/{@1}?firsthit
the above link is a bit wonky, you might have to copy and past the whole thing.
And I'm pretty sure this is the one for Montana:
http://data.opi.mt.gov/bills/mca_toc/61.htm
Not sure if these were posted in the thread somewhere, I was only going by what was posted on the first page.
icbm99 is offline
post #134 of 140 Old 10-28-2013, 11:17 PM
Ratmeat
OK, so I live in oregon, and am going to Utah and Colorado next summer to go wheeling. The links to all 3 states are broken. Looks like someone needs to update the links for at least these three states...
Doing my own thing, and being an individual since 1967!
A veteran is someone who, at one point in his life, wrote a blank check made payable to The United States of America, for an amount of up to and including his or her life. That is Honor, and there are way too many people in this country who no longer understand it.
Ratmeat is offline
post #135 of 140 Old 11-27-2013, 03:44 PM
cjlinn
Rivka,
Here is the KS statute link. There are two different articles regarding equipment etc.
http://www.kslegislature.org/li_2012..._0000_chapter/
cjlinn is offline
State by State Vehicle Equipment Laws Rivka Tires & Wheels 119 01-31-2017 08:57 AM
Looking for anyone in UP State NY that can weld good Heavysausage Fabrication Shop 0 06-03-2008 02:02 PM
Paying for out of state Jeep buy (Black_Jeep) General Jeep & Off-Road Equipment 0 01-11-2008 12:54 PM
Lift laws by state SCWrangler Tires & Wheels 51 04-05-2007 10:51 AM
maine state lift laws? mikevsgeek Tires & Wheels 0 03-29-2005 05:42 PM
