Quantcast State by State Vehicle Equipment Laws - Page 7 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > State by State Vehicle Equipment Laws
Old 03-07-2008, 12:47 PM   #91
krawler510
Maryland
For people that don't feel like digging; in addition to the drivers side mirror, your bumpers have to be below 28" front and rear.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline   Reply With Quote
Old 05-19-2008, 08:25 AM   #92
truckin88
NY has no fender flare law???
2006 Wrangler X, 6 speed manual 4.0 I6, BFG T/A's 31x10.50x15 on Promcomp )97 Soft 8 Steelies, stock sunrider soft top, KC Replacement fogs, westin step bars (yeah I know).
RED JEEP CLUB MEMBER #442
truckin88 is offline   Reply With Quote
Old 12-15-2008, 02:38 PM   #93
ziggy00001
I noticed someone posted a general link to the Transportation site for Saskatchewan, here is a direct link to the "Vehicle Equipment Regulations" document.
http://www.qp.gov.sk.ca/documents/English/Regulations/Regulations/V2-1R10.pdf
ziggy00001 is offline   Reply With Quote
Old 12-16-2008, 08:41 PM   #94
lmrsprt
what is the fender law /tire coverage for ohio
Yeah, I think we're screwed. There are not nearly enough of us and time is running out fast. One day we will tell our grandchildren what it was like to have once been free. They'll likely think us demented.
lmrsprt is offline   Reply With Quote
Old 12-16-2008, 10:11 PM   #95
JEEP97TJ
Have you tried to Search........
Blacksburg, VA
JEEP97TJ is offline   Reply With Quote
Old 01-28-2009, 11:57 PM   #96
wrangler_usmc
Need driver and passenger mirrors in Hawaii
Just talked to HPD...you need both driver and passenger mirrors if you take off the doors. Mahalo Hawaii....
wrangler_usmc is offline   Reply With Quote
Old 02-09-2009, 11:42 PM   #97
02tjsport
[*] West Virginia....WV Code Chapter 17C. Traffic Regulations and Laws of the Road
Equipment portions start with WVC 17 C- 15 - 1, scroll down in the side bar. Make special note of §17C-15-48
D F M
Is now http://www.legis.state.wv.us/WVCODE/Code.cfm?chap=17c&art=15&section=WVC%2017%20C-%2015%20%20-%20%20%201%20%20.htm#WVC%2017%20C-%2015%20%20-%20%20%201%20%20.htm
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 02-10-2009, 02:26 PM   #98
Whsperz
I have been working on trying to get the Alaska codes and regs. Had a city officer look over my Jeep and without the covers on the lights, the wheels exposed beyond the fender flares, the lift, and the large stinger on the front, he said there was no problems with it. He is supposed to be getting me the latest book of code standards. If I don't get it from him, I will roll over to State Trooper barracks and see if I can get one from them. The Alaska DMV web site is absolutely horrid to find this information.
The only one that I have been able to confirm as a code at this date is:
13 AAC 04.005. Disconnection or Alteration of Equipment
(a) For a vehicle intended to be operated on a public roadway, no person may disconnect or alter, except as is necessary in the repair or replacement of parts, equipment required by this chapter, unless the equipment is by nature designed and intended for disconnection or alteration;
(b) No person may operate a motor vehicle upon a public roadway which violates the following limitations or prohibitions:
(1) a motor vehicle may not be modified or altered from the original design so that any portion of the vehicle, other than the wheels, has less clearance from the surface of a level roadway than the clearance between the roadway and the lower most portion of any rim of any wheel in contact with the roadway;
(2) a motor vehicle may not be modified to position the lowest portion of the body floor more than three inches above the top of the frame, or to result in a maximum frame height or body floor height greater than 24 inches for a vehicle of up to 4,500 pounds GVWR, 26 inches for 4,501 - 7,500 pounds GVWR, or 28 inches for 7,501 - 10,000 pounds GVWR.
(c) No motor vehicle may be operated on a public roadway that has been modified, altered, manufactured, or is carrying a payload in a manner which adversely affects the steering, braking, or stability of the vehicle.
(d) A vehicle operated on a public roadway that exceeds the minimum or maximum specifications of subsection (b) must be in compliance with this section by 3/31/93.
(e) For purpose of this section
(1) "frame" means the manufacturer's main longitudinal structural members of the chassis of the vehicle, or, for vehicles with unitized body construction, the lowest main longitudinal structural members of the body of the vehicle;
(2) "frame height" means the vertical distance between the ground and the lowest point of the frame midway between the front axle and the second axle on the vehicle;
(3) "GVWR" means the gross vehicle weight rating as defined in AS 28.40.100 (a)(9);
(4) "payload" means anything added to a vehicle that increases its unladen weight.
Still working on these and will get more when I find good dated material(s):
Inspection of Vehicles 13 AAC 04.006
Emissions Requirements AS 45.45.400
License Plates Display of 28.10.171
Brakes Vehicles 13 AAC 04.205
Horn 13 AAC 04.210
Mirrors 13 AAC 04.220
Safety Belts 13 AAC 04.270
Tires 13 AAC 04.230
Unsafe Vehicles 13 AAC 04.225
Headlights Vehicles 13 AAC 04.020
Illumination 13 AAC 04.010
Miscellaneous Lighting Requirements 13 AAC 04.040
Parking Lights 13 AAC 04.070
Stop Lights Vehicles 13 AAC 04.035
Taillights Vehicles 13 AAC 04.025
I hope to find the location on the web but searches are not pulling up as much info as I would like.
2000 TJ, 1998 Grand Cherokee ZJ, 1983 CJ8 Scrambler (DJ Alaskan Postal Jeep) (FOR SALE!)
www.militaryjeepers.com
University of Louisville
Whsperz is offline   Reply With Quote
Old 02-11-2009, 10:56 PM   #99
azjpr
Just a quick note for AZ, lift specifications are under article #18 now not #16
azjpr is offline   Reply With Quote
Old 03-12-2009, 12:35 AM   #100
WsRpAoNrGtLtEjR
Thanks for the help. Quite a bit of reading, but I'm happy to know that in ILLINOIS, you only need 1 mirror. This is great news, because everyone told me if I took the doors off, I'd have to buy at least 1 more, for a total of at least 2. But it looks like I'm good with just the rear-view mirror on my windshield!
WsRpAoNrGtLtEjR is offline   Reply With Quote
Old 03-13-2009, 04:47 PM   #101
05WranglerLj
This is for Tennessee hope this is what you are looking for. http://www.michie.com/tennessee/lpext.dll?f=templates&fn=main-h.htm&cp=tncode It wont link straight to it but if you go there scroll down to title 55 thats the motor vehicles part. I believe chapter 9 is what you are looking for and then it narrows down even more in there. I found part 2 very helpful. I know its not a direct link, but I hope it helps some.
05WranglerLj is offline   Reply With Quote
Old 04-06-2009, 08:30 AM   #102
BlackBellamy
The New Jersey inspection laws are actually found in the Administrative Code, not the New Jersey Statutes.
http://www.michie.com/newjersey/lpext.dll/uanjadmin/1/a94cf/ac806/ad4cd
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline   Reply With Quote
Old 04-27-2009, 09:40 PM   #103
jakemary
1977 CJ7
any link for MN?
I asked a cop about going doorless on a xj and he had no Idea.
jakemary is offline   Reply With Quote
Old 05-12-2009, 11:05 PM   #104
jeepster2
1978 CJ5
Smog Certificate Required
California says no smog on vehicles 1975 and older. I have a 1978. On what year will I no longer need a smog certificate? At that time can I remove all smog equipment and/or drop in a different motor?
jeepster2 is offline   Reply With Quote
Old 05-20-2009, 08:49 PM   #105
hartke20g
Florida vehicle codes
http://www.lowestpricetrafficschool.com/handbooks/driver/en/5
hartke20g is offline   Reply With Quote
Glock Forum
