specs on Lj - JeepForum.com
post #1 of 9 Old 05-11-2011, 10:28 PM Thread Starter
austonreeves
specs on Lj
I'm gunna trade in my tj for an lj and I was wondering what alll is different other than the wheel base
austonreeves is offline
post #2 of 9 Old 05-11-2011, 10:34 PM
threeb
There is spec section that will tell you everything about both.
Sent from my iPhone using my fingers
LJ Owners Group member #431.
threeb is offline
post #3 of 9 Old 05-12-2011, 04:30 AM
RogueSpear2023
Nothing is different other than the wheelbase and total length, you will find the info you need in my sig in the TJ specs.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 9 Old 05-12-2011, 11:21 AM
scrambled
The LJ's came stock with a rear dana 44, other than the wheelbase and interior room, thats it. Get an LJ you will not be dissapointed.
2014 JKU Rubicon X-2002 Grand Cherokee Limited
Past: 2003 TJ Rubicon, 2006 LJ Rubicon Rubitrux
scrambled is offline
post #5 of 9 Old 05-12-2011, 03:02 PM Thread Starter
austonreeves
It's either that or a jk but I really don't want the 4door but I want more room than my tj
post #6 of 9 Old 05-12-2011, 03:13 PM
Whobeme
2010 JK Wrangler
LJ's also have rear disc brakes, limited slip, 3.73 gearing, and a transmission skid stock.
Whobeme is offline
post #7 of 9 Old 05-12-2011, 03:39 PM
scrambled
Forgot about that...
Between the LJ and the Jk, I have both and they are nice in there own way. The room in the JK is great. However is it big, and very different from the LJ. My LJ is half-cabbed so its a little different but I still love the space. Its really want you want. I didn't like the JK's at first, but after owning one it has grown on me.....
post #8 of 9 Old 05-18-2011, 08:39 PM
lucky-13
Definitely go with the LJ - the longer wheelbase alone is worth it for the improved road handling but it's not so much longer that it will affect off-road performance much (if at all).
Colorado Jeep Club Member #513
05 LJ Rubicon Sahara #787 : 6" Skyjacker Longarm Lift
07 WK Overland : It's all about the Hemi : XK/WK Owners Club Member #13
lucky-13 is offline
post #9 of 9 Old 05-19-2011, 02:54 AM
DallastheJeeper
The LJ has a rear dana 44 with disk brakes and a limited slip diff. All the extra length is behind the back seat so
I re drilled my seat brackets for the back seat and gave my passengers 4'' more of leg room so no more *****ing about having to sit in the back seat. I had a 98 TJ before mt lj and I think the Lj is better. The only downsides to the LJ are they Dont have the insane turning radius as a TJ, Skid plate drags on more stuff due to the longer wheel base but you can raise the skid and lift it without having to do a SYE since the drive shaft is twice the length of the Tj Finally my biggest issue with my LJ is how long the sides of the top are, they look kinda weird but that also makes it unique, I plan on getting a trek top NX which looks amazing on ljs since the roll cage has a slant giving it the fast back look.
So Get the Freakin LJ and you will love it!!
Here is a couple of pics to get you in the mood.
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
