Quantcast SMITTYBILT XRC8 Winch arrived today... details, pictures, etc... - Page 5 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > SMITTYBILT XRC8 Winch arrived today... details, pictures, etc...
Old 07-27-2007, 07:27 PM   #61
1 ton yj
Is your bumper welded to the frame? Cut that silly tube out. It'll make your life easier.
1 ton yj is offline   Reply With Quote
Old 07-27-2007, 07:40 PM   #62
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
pay no attention to the red and black cables... those were to test fit wiring... but do pay attention to the hideous color coded yellow and blue boots.... the control box mounts on top of the motor if you set it up as it comes out of the box..... and you woudl have a yellow wire and a blue wire goign to the motor from there..... yuck. i'd be buying new wire that was red and black if i was going that route for sure... eww that's ugly. haha
yea the bumper is welded to the frame.
i would have cut that tube out today but i have no way to do it other than an angle grinder with a cutting wheel.
tomorrow i'll probably go up to the shop and plasma it out so i can actually get to the bolts
only thing is i gussetted the winch plate/bumper top to the tube so it wouldn't peel... i could go about that another way though.... we'll see, haha
-Erik <--- loves finding excuses to play with the plasma
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
Old 07-27-2007, 08:58 PM   #63
chupacabrah
Originally Posted by Big-n-Broke-YJ
-Erik <--- curious if anyone else has bought one of these yet
I'm thinking about it...kinda torn between this one and that atlas 9500lb. the atlas is series wound, more hp, same gearing...made in china. more current draw.
but i also have to wait for approval....the gf says when she gets a diamond ring, I can get a winch
so...soon...on both counts
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
Build Thread
jeep stuff
chupacabrah is offline   Reply With Quote
Old 07-27-2007, 09:22 PM   #64
Grape Ape
I'm tired
Grape Ape's Avatar
Originally Posted by jeeepguy
This is why I made my statement:
"And if you're referring to a winch situation where submergance is a concern, it wouldn't be practical to use an electric winch by any means"
Sorry but no... if the winch were submerged, an electric won't work and you wouldn't want it to. ONLY hydro winches work underwater, and yes, only if the engine is running. In that case, time for the Hi-Lift...
That is incorrect an electric motor will work just fine completely submerged in water and when dried out it will also work just fine. I am a safety instructor and use a 3/8" drill to demonstrate ground fault current interrupting outlets. I turn the drill on lock it at full speed and lower it into a 5 gallon bucket of water. It will run all day long. There is no harm in doing it. The issue comes in completing the circuit from the motor to ground through your body such as holding the drill in your hand and standing in a puddle. It is amazing how many people, electrical engineers and electricians who think that the minute the drill hits the water it will quit working or blow the circuit breaker.
In the situation described of a winch motor your connection will not occur you will be safely separated by the winch being in the water any ground will go to the steel of your vehicle if it is even a factor. I would not hesitate for a minute to use a submerged winch if it was what was needed to get out of a jam.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things...
...the people you meet and the books you read. Charles E. Jones
Grape Ape is offline   Reply With Quote
Old 07-28-2007, 06:16 AM   #65
Devildog985
BnB YJ, I am not a welder so I was just going to order a winch mounting plate for $65.00 that is made for the yj do you think that will work or are the mounting plates junk? Well let me refraise that I can weld but instead of a cable braking it will probably rip my welded plate off
1994 YJ 5" bds Lift with M.O.R.E 5/8 boomerange shackles and BDS stretch, 1" Daystar Bl, SYE/W XJ d/shaft 8.8
YJ Nation - Big Jim Team YJ - The Revolution Begins
Devildog985 is offline   Reply With Quote
Old 07-28-2007, 08:50 AM   #66
ovrlnd
i have to say that it is completely possible to operate an electric winch while submerged.
I have done it with my rep 8000 on at least 7 separate occasions and have had no problems. the biggest problem is cleaning and re-lubing it after to make sure no silt or water contaminated the winch.
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
ovrlnd is offline   Reply With Quote
Old 07-28-2007, 09:23 AM   #67
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
electric winches do work under fresh water. fresh water does not cause electrical shorts, only salt water does.
There is absolutely nothing wrong with a winch plate. In fact, the A to Z Fabrication one if what I planned to buy originally... but then I got to thinking about it and I liked the look of a winch plate being built into the bumper and since i already made my bumper I wanted to do my best to keep it looking like a clean functional "winch" bumper... which is the only reason I didn't want a winch plate.....
As ugly as they are, the harbor freight winch plates work great and they're cheap. something to keep in mind.....
UPDATE: took better pictures of how i made the fairlead mount and with the iwnch installed. those last night were way too dark.
-Erik <--- is doing some wiring today!
Old 07-28-2007, 10:57 AM   #68
1 ton yj
That came out good.
Old 07-28-2007, 07:14 PM   #69
Devildog985
Man you aint a kiddin. That looks sweet. Nice job.
Old 07-28-2007, 08:20 PM   #70
learfxr
Nice, let us know if it's worth the money and functions well. I'm thinking about ordering one if you think it's a smart investment. Otherwise it will probably be the Warn M8000
1989 YJ Islander
TBI350 4L60E BDS lift.
Wag axles, 38 TSL's, 4.56 gears
1995 ZJ Orvis Edition 5.2L
3" lift and 32's.
learfxr is offline   Reply With Quote
Old 07-28-2007, 09:15 PM   #71
jeepin1995
jeepin1995's Avatar
that things too clean!!! go get it nasty!!
when you wheelin again?
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
WWW.FLATLANDROCKCRAWLERS.COM
350 in my YJ.....
http://www.jeepforum.com/forum/f12/my-350-swap-518364/
build thread:
http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/
jeepin1995 is offline   Reply With Quote
Old 07-29-2007, 12:07 AM   #72
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
went today @ mayfair.... gave it HELL.... danny broke his front ring and pinion or spider gears... we're not sure which yet... we THOUGHT my broke my spider gears but it looks like I just busted a hub.
I'll be out there again sunday, haha. i yanked off my diff cover to inspect things so i guess while i have it off i might just go ahead and weld it, haha
-Erik <--- says to send an email if you wanna go. efrancin@ec.rr.com
Old 07-29-2007, 12:37 AM   #73
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
UPDATE:
as for wiring today i got some 4 awg battery cable from the parts store and some connectors for the ends... i got some heat shrink tubing from lowes, and some 16-4 in-wall cl3 speaker cable from lowes to use to extend the remote plug that i put in my dash.
i'm mounting the control box to the front of my battery tray, vertically. i moved the solenoid pack up higher in the box and had to drill new holes to do so obviously.
i went to circuit city and bought stereo battery terminals for all my wires (new and old) but found that i wasn't thinking properly and they won't work b/c my wires are too big. best buy carries battery terminals for $15 that will handle two 4 awg wires and another for about the same price that will handle 2 4 awgs and 2 8 awgs.... tomorrow i'll get those and the install will be done!
i'll post pictures after i get home from wheeling
-Erik <--- probably won't need it, but it will be nice insurance
Old 07-29-2007, 09:26 AM   #74
Skeezer
My winch runs better submerged, it's watercooled.
2006 TJ Sport
1995 YJ
2007 JK Sahara Unlimited
www.GrassRootsJeepClub.com
www.GrassRootsJeepClub.proboards80.com
Skeezer is offline   Reply With Quote
Old 07-29-2007, 12:47 PM   #75
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
hehe, good call
update: i unspooled and respooled the wire today and though its not the fastest thing in the world it didn't have any hiccups, bumps, or any farts along the way. the free spool / engaged knob worked fine, the forward reverse on the remote worked as it should, and the motor didn't really get all that warm.
knowing that i only have one yellow top and a stock alternator i only ran it for 20 seconds at a time with a 20-30 second break in between sessions. no sense in being in a hurry and burning up a voltage regulator or overheating the somewhat sketchy permanent magnet motor......
i also got bored while changing my diff fluid and welded my front spider gears so i'm off to do some wheeling to see just how horrible my steering is... perhaps i'll get stuck while i'm out
Glock Forum
