#46 | ||||
BUILT. NOT BOUGHT.
I built my front bumper to be basic and effective.... and it is... but i never thought i'd have a winch so that wasn't thought into the planning... hence the reason my mounting will be different/odd..... but yes, i will post pictures once i mount it. I can't do that until i get my gas cylinder filled though... hard to weld without gas ![]() Quote:
Now when I used it (a dozen or so times) to winch out friends, it was great.... but i didn't buy a winch to help others... i bought this to help myself.... UPDATE: i clocked the transmission part of the winch tonight. that's not the right name by any means but that is essentially what it is so that is what i'm going to call it for now.... it was pretty easy... just unbolt the two allen's that hold the two rods to the tranny (the big chrome rods that run from side to side) and then remove the tranny. Once you remove it you unbolt all the 12 or so metric allen screws and clock it accordingly. then replace the allens (thread them all first... don't tighten any until they have all been threaded). then sit the winch on the motor side and sit the drum in place and then sit the tranny in place. be sure not to mess up any of the seals and be sure to take your time getting the gears and shaft to seat correctly. then replace/tighten the two big allen bolts on the chrome rods and you're good to go! ![]() ![]() ![]() ![]() CLOCKED! now i can access the free spool/engagement lever without it hitting my bumper's light hoop... -Erik ![]()
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#47 |
Erik how is your front bumper built? Mine is welded to the frame and plated on the sides. My crossmember tube is long gone, I'm probably going to sink mine into the frame and build the fairlead into the bumper. There is plenty of room between the rails for it.
#48 | |
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it. User CP > Options > Uncheck "Show Signatures" |
#49 |
BUILT. NOT BOUGHT.
my bumper has a 1/4" plate that goes fromf rame rail to frame rail and then all the way back to the grill's body mount.
i don't want the fairlead sticking out farther than it has to so in order to do that the winch needs to be moved up a little to keep the fairlead in line with the bottom half of the drum where the cable comes out. the front of the bumper is 1/4" 2x4" square tubing so going through that for a recessed look is pretty much impossible.... ![]() ![]() i still have the round crossmember between the frame rails.... i plan to weld 2" 1/4" flat bar that i have laying around from that crossmember to the (bottom side) back edge [or close to it] of the bumper to reinforce it so the winch doesn't "peel" the bumper.
#50 |
Senior Web Wheeler
Erik,
You must have very little backspacing on those wheels huh?
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter. 98 XJ build thread |
#51 | |
Thanks for the great writeup. Very informative and unbiased.
U.S. NAVY JEEP HULL # 980
GEAUX TIGERS P.S. The plane will fly! |
#52 |
hey erik, maybe i missed it, but where did you order this winch from for that price?
#53 | |||
BUILT. NOT BOUGHT.
![]() i like the wide look if youc an't tell, hehe Quote:
got it in 2 days....-Erik
#54 | |
The reason I ask is because it seems like you could get wide axles and then wheels with lots of backspacing and be able to do 1-tons without having to narrow them, but still having a normal-ish track width. |
#55 | ||
#56 | |
#57 | ||||
And if you're referring to a winch situation where submergance is a concern, it wouldn't be practical to use an electric winch by any means. This is an old arguement and everyone has an opinion... I wouldn't have an electric winch with its assorted electrical load, heating, stalling and motor/solenoid failure issues. To each his own... but I'll take reliability and durability anytime, thus a hydro winch.
"Si Vis Pacem Para Bellum" Quote:
#58 |
BUILT. NOT BOUGHT.
nothign wrong with a hydro winch if it meets your needs... i know you can get hydraulic pumps and so forth so that in the event your engine does fail you are still able to winch, but that just doesn't seem very practical for MY particular needs.
I'd probably have a much less biased opinion about them if it wasn't for the failure i experienced.... I hydrolocked my 304 while crossing a creek and at that time i NEEDED it as water was up to my headlights and trying to take my jeep down stream. An electric winch would have gotten me out, and for that reason alone... i'll be electric from here on out. Solenoid failure isn't as normal as many make it out to be... and even if a solenoid did fail... jumper cables from the winch motor to the battery and you're back in business..... UPDATE: mounted the winch, still working on the wiring.... lesson #1: don't build a bumper and expect adding winch provisions to be easy down the road when that day comes... it's not. i just spent 4 hours grinding and cutting up flat bar to add a gussetted fairlead mount and adding gussets to the underside of the winch mounting plate (top of my bumper) to keep it from peeling/bending, Then I spent 30 minutes tryign to get wrenches up in the tiny space i left myself to work with around the winch's mounting bolts. ugh. Still can't get the front two... need a stubby open ended 5/8" wrench ![]() -Erik <--- curious if anyone else has bought one of these yet PS- off topic but my next set of wheels will likely have quite a bit more backspacing ![]()
#59 | |
Senior Web Wheeler
I have a set of 2.5" BS wheels on the way. They are 15x8 though so I think my ball joints won't scream too much. I assume getting an inspection is not an option for you with the tires that far out. I may actually end up getting some cheapo backup wheels & tires for the inspections ... You should look at some H2 wheels if you ever want an inspection. I think there are a few guys on here running those. On the wiring side I think I read you are gonna wire in the plug for the controler instead of just hardwiring the whole thing. I say good call. There may be a time that you do not want to be in the vehicle while you are winching ![]()
#60 | |||||
"And if you're referring to a winch situation where submergance is a concern, it wouldn't be practical to use an electric winch by any means" Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
