SMITTYBILT XRC8 Winch arrived today... details, pictures, etc...
#31 | |
don't fear the Jeeper
thanks for the good write up and info.
I seriously don't think you'll need that fairlead, so U can just send it to my house! I'll do ya a favor and take it off your hands! ![]()
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <>< |
#32 | |
Just a bit of advise..
88 Jeep YJ Wrangler
GM 5.7 TBI V8, 700R4, NP231C/J, 4.5" RE HD lift, SYE, Tom Woods rear DS, Winch w/synthetic line, Tomken Bumpers, Optima dual batteries, Custom electric fan, LED Tail Lights, York On-Board-Air Setup, 1991 Celica GT seats, Home made snorkel.... Also Dana HP60 front and Dana 60 Rear are now being installed SOA. Engine under construction again, 4.3 out and 5.7 going in.. My DIY Snorkel write up Click here.....Homemade Snorkel Chevy 4.3 Conversion Click here.....4.3 Chevy Conversion |
#33 |
this thresd is perfect. i was just about to start one asking about this winch. great price, hopefully itll be good enough for some abuse. thanks for the updates and keep posting bout this winch please
1997 TJ 5.5" long arm kit, 35x12.50 bfg m/t's, d44 front/rear 4.88 gears with arb lockers ALWAYS ACCEPTING DONATIONS!!! |
#34 |
for info, here is the winch I mentioned earlier I was looking at
http://www.gregsmithequipment.com/Atlas-9-500-LB-Winch-p/atdf9500.htm |
#35 |
this should be stickied.
1995 YJ 2.5 31's, BestTop Super Top, Herculined tub, fog lights, TJ rear bumper Low Output 4 Cylinder Jeep Club Member #68 JeepForum Night Crew #75 |
#36 | |
Senior Web Wheeler
http://www.pc-control.co.uk/dc-motors.htm Granted it's on a completely different scale, but I remember as a kid taking apart a lot of my little Tyco slot cars to remove pet hair .... and they never seems to run as well afterwards.... but then again, I was 8 so who knows WTF I did to em ![]()
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter. 98 XJ build thread |
#37 |
BUILT. NOT BOUGHT.
The problem is where would it be best stickied if it was even important enough to stickie?
this certainly isn't the most appropriate forum for this thread.... I posted it here b/c you guys are like my extended family and I thought that if any tight wad members would be interested in a cheap winch it would be you guys ![]() the Technical Articles & Write-Ups forum might be a better place for it... i was going to post it there to start with but I thought that you guys would benefit more seeing it in front of your face rather than searching... since it seems most people lack the knowledge of the search feature ![]() update time: that piece of magnet that appears missing in the picture... it is.... i just check out my full size pics and sure enough a chunk is missing out of that corner.... i thought perhaps i damaged it taking it apart but seeing as i did it on my white carpet and there is no magnet chunks anywhere to be found i suppose this was a factory defect. ![]() i'm not goign to do anything about it now.... i'm going to install the winch as-is and test it out. if it works fine, and i assume it will, then i'll use it until my season of fun is over and then handle it via warranty. it'll be an easy 5 minute swap to install a new motor so no biggie here. i'll email smittybilt in the meantime to make them aware of my problem and see how they plan to handle it. if they will just send me a new motor then i'll install it and keep this one as a spare.... we'll see ok... i'm going to install this thing... updates to come tonight if i get to test it by then! -Erik
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#38 |
Just call me Moose
Nice info so far, Erik. Can't wait to see it mounted.
#39 |
Post some pics also on how you mounted it to.
1994 YJ 5" bds Lift with M.O.R.E 5/8 boomerange shackles and BDS stretch, 1" Daystar Bl, SYE/W XJ d/shaft 8.8 YJ Nation - Big Jim Team YJ - The Revolution Begins |
#40 |
So my guess this magnet is bad??? j/k this is to a milemarker 8500 i believe I just called them today about a replacement motor price they are supposed to email me the price.
#41 | |
Senior Web Wheeler
Anyone know if a Warn motor will bolt into either the Mile Marker or this Smitty unit?
#42 | |||
Hmmm... well... you could just go with a hydro winch and be done with it.
"Si Vis Pacem Para Bellum" Quote:
#43 | ||
Part of the Three Percent
www.pghoffroad.com My SOA Build Recovery Gear Basics My BUDGET York OBA Install Budget Welding Cart Carling Contura Switch Panel If it has tracks, tires or tits, its gonna cause a problem. "Everytime someone installs a S35 kit or otherwise "upgrades" a D35, an angel looses its wings." Quote:
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP) |
#44 | |
The funny thing about this signature is that by the time you realize it doesn't say anything, it's too late for you to stop reading it. User CP > Options > Uncheck "Show Signatures" |
#45 | |
Magnets are funny this way as if you were to break a peice off a magnet it work it would oppose it self from the rest of the magnet and bounce off or repel off and go flying.. It is the whole north and south thingy with magnets..
88 Jeep YJ Wrangler
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
