Should i use 4 low on the beach - JeepForum.com
post #1 of 22 Old 10-22-2013, 07:33 PM Thread Starter
longislandxj
1994 XJ Cherokee
I everyone i have a cherokee on 31's and stock gears should i use 4low or 4high on the beach
Which one will be more friendly on my transmission?
longislandxj is offline
post #2 of 22 Old 10-22-2013, 07:38 PM
gojeepgo
1981 CJ7
It all depends on the sand. If it is soft I use 4 low. If it is hard packed I use 4 hi.
Dont forget to air down.
gojeepgo is offline
post #3 of 22 Old 10-22-2013, 07:43 PM Thread Starter
longislandxj
1994 XJ Cherokee
Ok thanks!! Any equipment besides a jack and some 2'x2' plywood you would recommend bringing
post #4 of 22 Old 10-22-2013, 07:58 PM
GilaMtnJeep
GilaMtnJeep's Avatar
A 30k strap can be handy.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 22 Old 10-22-2013, 08:01 PM
gojeepgo
1981 CJ7
shovel, jack, lug wrench, wood for jack base, shovel, tow strap ( a good one without hooks on the ends ) and a shovel.
gojeepgo is offline
post #6 of 22 Old 10-22-2013, 09:39 PM
N128CG
Don't forget the shovel.
N128CG is offline
post #7 of 22 Old 10-23-2013, 07:32 PM
GilaMtnJeep
Indeed. No metal on the ends.
Oh, did anyone mention a shovel??
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #8 of 22 Old 10-23-2013, 08:00 PM Thread Starter
longislandxj
1994 XJ Cherokee
Ok tow strap will be the next thing i get then👍
post #9 of 22 Old 10-24-2013, 01:59 PM
Dngrs1
1979 CJ7
A folding shovel would be a good idea.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #10 of 22 Old 10-24-2013, 02:07 PM
ChrisHager
Administrator
ChrisHager's Avatar
shovel...
...shovel...
...and a shovel.
Eh?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #11 of 22 Old 10-24-2013, 02:32 PM Thread Starter
longislandxj
1994 XJ Cherokee
Ok so i think i might need a shovel lol
Thanks guys
post #12 of 22 Old 10-25-2013, 01:54 PM
Tdog
I play in a lot of sand and using low spins the motor faster to help cool the motor.
Tdog is offline
post #13 of 22 Old 10-25-2013, 02:35 PM
wilson1010
Yet another reason for electric fans
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #14 of 22 Old 10-25-2013, 07:17 PM
uberxj92
1992 XJ Cherokee
Forget the shovel bring a Mexican back hoe.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #15 of 22 Old 10-25-2013, 07:40 PM
Fletchlives85CJ
air down, easy on the gas until you are in a higher gear, SHOVELS AND FRIENDS, and a good long snatch strap with some stretch in it....seen 2wd minivans cruise every where with a decent driver and street tires at Pismo dunes
Fletchlives85CJ is offline
