Should I rebuild my axle when installing a locker? - JeepForum.com
post #1 of 12 Old 02-15-2014, 08:53 PM Thread Starter
bobfoe95
Will be installing my front lock right in my dana 30 here shortly. Should I pick up a rebuild kit while doing this? I am in a ZJ on 31s.
bobfoe95 is offline
post #2 of 12 Old 02-15-2014, 09:52 PM
rjbruzan
At a bare minimum I would put inner diff seals in. About 8 bucks each at Rock auto. Also change out the Ujoints while in there.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 12 Old 02-16-2014, 06:40 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Since you don't even need to pull the carrier for those cheap lockers, I wouldn't bother. If you were doing gears and had to pull the carrier and pinion, absolutely.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 12 Old 02-16-2014, 07:40 AM Thread Starter
bobfoe95
Besides inner seals is there anything else (Besides the overhaul) I should really do with the locker?
bobfoe95 is offline
post #5 of 12 Old 02-16-2014, 08:17 AM
rjbruzan
universal joints
rjbruzan is offline
post #6 of 12 Old 02-16-2014, 04:02 PM Thread Starter
bobfoe95
Ok this is a dumb question but I am struggling to find the answer. How many universal joints will be on my front axle? 2?
bobfoe95 is offline
post #7 of 12 Old 02-16-2014, 07:01 PM
rjbruzan
One on each side in the steering knuckle. 30-50 bucks each.
rjbruzan is offline
post #8 of 12 Old 05-03-2014, 03:01 PM Thread Starter
bobfoe95
Is the inner differential seal the same as the inner axle seal?
bobfoe95 is offline
post #9 of 12 Old 05-04-2014, 06:40 PM
rjbruzan
yes.
They are changed with the carrier removed.
rjbruzan is offline
post #10 of 12 Old 06-13-2014, 02:47 PM Thread Starter
bobfoe95
Ok locker is going in tomorrow. Any last minute items?
bobfoe95 is offline
post #11 of 12 Old 06-13-2014, 03:46 PM
gregstudeny
2006 WK
Gear oil.
gregstudeny is offline
post #12 of 12 Old 06-16-2014, 04:11 PM
Steve936
Adequate beverages in an equally adequate cold storage device.
Tar Hollow Off Road Expeditions
Steve936 is offline
