Shocks question? - JeepForum.com
post #1 of 11 Old 05-29-2012, 10:22 PM Thread Starter
baked
Shocks question?
Alright, I have a 4" rough country lift on a 08 jk and as everyone knows the shocks ride SUPER stiff and I'm tired of bouncing around! So I'm considering buying a set of factory performance fox shox, now is it as simple as replacing the rough country shocks with the fox shox? Or is it more technical than that?
baked is offline
post #2 of 11 Old 05-29-2012, 10:58 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Good shocks like Bilstein will help the ride a bunch, However Better springs will help a lot also !
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 11 Old 05-29-2012, 11:04 PM Thread Starter
baked
Thanks! But theres no complications with switching out shocks with a different brand than the lift? Hence rough country lift with fox/bilstien shocks? All you do is take the old shocks out and put the new ones in?
baked is offline
post #4 of 11 Old 05-30-2012, 12:03 PM
tjcj
You can run any shock of your choosing with the RC lift. X2 on the Bilsteins
Yakima Valley Mountaineers.
tjcj is offline
post #5 of 11 Old 05-30-2012, 01:54 PM
RogueFab
X3 for bilstein. Although fox is also high on my list. They should bolt right in as long as the travel and collapsed length is the same as your current equipment. Call product support if they don't have that info easily available.
RogueFab is offline
post #6 of 11 Old 05-30-2012, 02:05 PM
LittleBluE
I hear fox shox ride really well especially with correct valving. If your willing to spend the time and money I would say the fix due to the customizability but if you want good shocks right out the box, bilstein 5100's or rancho 9000xl's are fully adjustable and ride great I heard and they're priced reasonably.
Good Luck
Nick
LittleBluE is offline
post #7 of 11 Old 05-30-2012, 05:48 PM
muddr1
I just installed a set of Rancho 9000's and love them. They are adjustable. On 1 they aresuper soft, I have them on 3 right now and still have a great ride. I looked into bilsteins and heard they give more of a hard ride. Not what I wanted.
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #8 of 11 Old 05-30-2012, 06:30 PM Thread Starter
baked
The guys at the 4x4 shop said to go with the ranchos too because they are adjustable and everything so I can set it how I'd like
baked is offline
post #9 of 11 Old 05-30-2012, 11:55 PM
LittleBluE
Yep. I told you can't go wrong with the ranchos. They're great shocks, and reasonably priced too.
And yes bilsteins are a bit stiffer
post #10 of 11 Old 05-31-2012, 01:10 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Fox shocks are great but if your rough country springs are still rough (I know the Yj sets are lower than garbage) then your springs are just going to fight your shocks and then you're back at square one.
Luck Favours The Prepared
Anticanman is offline
post #11 of 11 Old 05-31-2012, 01:50 AM
LittleBluE
Agree. OP should get currie/aev springs. They ride great with rancho 9000's
