Quantcast Sanden OBA Oiler? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Sanden OBA Oiler?
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 05-14-2006, 03:29 AM   #1
jeepfury
Sanden OBA Oiler?
Ok I am just buttoning up my OBA system with the sanden but noticed something. I am currently using a Craftsman in-line tool oiler on the intake side of my sanden and I don't think its feeding right? The compressor got pretty hot after running it for about 4-5minutes. Is that normal? It seemed to have used very little oil also. Is that normal too? I am using Ignersoll Rand All season synthetic compressor oil if that matters. Also should I be able to run the sanden on pretty heavy duty cycles or no? If anyone thats knows of sanden OBA or has one and could shed some light on my questions that would be awesome.
This is the exact oiler I have on the Intake side of my sanden http://www.sears.com/sr/javasr/product.do?cat=Compressors+%26+Air+Tools&pid=00916 309000&vertical=TOOL&subcat=Air+Tool+Accessories&B V_UseBVCookie=Yes
Is there a better one than this?
JOOP
00 Cherokee Classic- Stock
jeepfury is offline   Reply With Quote
Old 05-14-2006, 03:55 AM   #2
92 Green YJ
Head Brewmaster
92 Green YJ's Avatar
i used a drip feed oiler meant for a compressor for mine. got it at Lowes for like 10 bucks. when the compressor is running you should see oil flowing through the lubricator, if you don't see oil flowing in, it aint working right. you have it hooked up on the air in line to the compressor right?
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Old 05-14-2006, 09:18 AM   #3
TSEJEEPERS
I started off using one like the one you are using. It did not work right for me either. Now I am using this one. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42035 You can split them up and use the oiler to oil the compresser and the dryer to take it out.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 05-14-2006, 10:01 AM   #4
TellyDSP
Poland and PPV!!!!
you can split these? THey have a few different version at HF right now, but they were useless to me without splitting. Looks like I'm going back there again, even though I already did my weekly stroll.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Old 05-14-2006, 07:39 PM   #5
TSEJEEPERS
Yes you can split them. The only problem I have had is the regulater/dryer where the knob is to adjust leaked I used some teflon tape and tighten down. It seems to work alright now.
Old 05-14-2006, 09:19 PM   #6
92 Green YJ
Head Brewmaster
you mean you didnt use teflon the first time? no wonder it leaked. I used teflon paste on all my connections, no leaks at all anywhere
Old 05-14-2006, 09:30 PM   #7
TellyDSP
Poland and PPV!!!!
I thought he was referring to the factory assembled part where the regulator adjustment knob is.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Old 05-15-2006, 08:31 AM   #8
TSEJEEPERS
Yes I was refering to the factory assembled part.
Old 05-18-2006, 01:28 AM   #9
RARECJ8
i've used one of these for many years with no issues. very clean and no mess. as for lubing my sanden, i annually unscrew the top bolt and just squirt in a few inches of grease.
simple.
good luck
http://www.powertank.com/products/sfID1/16/productID/60
mb
Life member BRC
Cal4Wheel
www.hillsangels4x4.com
RARECJ8 is offline   Reply With Quote
Glock Forum
