Quantcast rusty frame - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > rusty frame
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 03-02-2008, 09:26 AM   #1
jbjeepin
rusty frame
lookin at a 2002 jeep looks great except it is from up north. The frame has rust on it . Not sure about the body underneath. The exterrior is flawless.Can it be remedied or would it be better just to pass up this jeep. It is a pretty good deal unless major problems will likely result from salt exposure.
jbjeepin is offline   Reply With Quote
Old 03-04-2008, 10:32 PM   #2
Brandon_YJ
1987 YJ Wrangler
How much rust are you talking about here?
My jeep is 21 years old and has spent its entire life in Michigan and though the frame is scaled with rust it appeared to be structurally sound when I examined it on a lift at work last night.
Brandon_YJ is offline   Reply With Quote
Old 03-04-2008, 11:38 PM   #3
goatboy
Depends if it's rust or rot...if it's rot, pass...
goatboy is offline   Reply With Quote
Old 03-05-2008, 07:35 PM   #4
jbjeepin
definately not rot.It appears to be mainly surface or some scale rust
Old 03-07-2008, 10:34 PM   #5
ISUzj
1994 ZJ
well I think that it is a real solvable problem, you might have to take a close look at joints to see if it has affected the structural intergrity that but i highly doubt it, it would really have to be a lot of salt to wear a frame that new to rust....probrably blast it, or wirebrush it, and just put on some roll on bed liner or paint it it if you are that concerned about it
ISUzj is offline   Reply With Quote
Old 03-13-2008, 09:34 PM   #6
tiggergirl921
Are there any places (like Maaco or local auto body shops) that offer rust treatment service for a problem like this? I mean, I would imagine that it's a pretty common concern...
tiggergirl921 is offline   Reply With Quote
Old 03-16-2008, 07:24 PM   #7
jbjeepin
nor sure. I am going to spray any rusted spots with phosphoric acid which is easier than brushing then cote with some kind of sealant. Supposedly the acid converts the rust to primer and seals against further damage. However it still needs to be sprayed with a sealer after. Ill let you know how it turns out
Glock Forum
