#46 | ||
I had a chain rated at 4k and it was big, way to big to drag around on a trail. Recovery starps can be rated at about 10xs that and only weigh a few pounds.
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more "If you aim at nothing, you will hit it every time." — Zig Ziglar |
#47 | |
I had managed to "float" and wheel spin it through a marshy mess, and I made the mistake of stopping in the middle so it promptly got stuck and eventually sank up over the tires. Afterwards we figured out that if I had spun the wheels a bit to break the suction it probably would have come out easier.. it was in there like a stuck boot. Many lessons learned.
02 TJ Sahara, 2.25"BB + 1.25" BL, 32" Maxxis Bighorns |
#48 | ||
4.46 vs. 4.06
#49 | |
I have to disagree with over torquing your shackles. I have taken rigging classes through the job, and a master rigger taught us to tighten down the shackle pin, the actually loosen it a hair. The reason for this is, that if for any reason you needed to loosen the shackle while under load, you would be able to. |
#50 |
Lots of good points;
I would avoid trying to pull in reverse (unless there is no other option). Forward cut differential gears are 25 to 30% weaker in reverse and many have been broken this way. The proper way to rig a tree strap is to use a shackle since there is less chance of the tree strap slipping off of a shackle than a hook (don't depend on those flimsy safety latches that come on the hooks). Properly rigged there is little difference between the (I believe, now obsolete) quick pin type of shackles and the screw type. When improperly rigged the screw type has a substantial advantage as the pin is retained by threads instead of a piece of relatively thin spring wire. I torque shackles only finger tight as I see no advantage to over tightening for winching operations. If a vehicle is securely stuck in mud pulling at an angle or sideways on one end some times will break it free when a straight pull (forward or back ) has no affect. Looping straps through each other is a bad idea (if you don't put a rolled magazine or towel etc in the "knot" as the knot can tighten to the point where it is nearly impossible to untie. When evaluating an extraction I normally make the owner make the connection to their own vehicle so there will be less problem if I pull some thing off (I have pulled off bumpers and trailer hitches that looked securely attached but were not). I think twice about helping people who do not have tow points as the chances of damage to their vehicle is increased. When tying off the frame to a tree I use 2 rear tow points (one on each side of the rear bumper/crossmember) to avoid tweaking the frame into a diamond shape when winching. When attaching two vehicles together to drag out a third; put the lightest vehicle the farthest from the stuck vehicle to help avoid tweaking its frame. When helping extremely stoned or drunk people make them stand under a tree while someone else handles their vehicle. Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway. Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road. |
#51 |
Jeepin Down South
#52 | |
NOO! Linking 2 straps with a D-ring is just as bad as using a strap with metal hooks. If something goes wrong, the D-ring becomes a deadly projectile. Also, looping one strap through the other and back through itself places stress on parts of the strap that aren't designed for it. Check out the Video with John Rich @ 4:10...he demonstrates how to properly connect 2 straps using a "figure of 8 knot". Also, to you guys using shackles with screw pins...You're supposed to hand tighten the pins, then back them off 1/2 turn. Again, the video with John Rich demonstrates that too. |
#53 | |
Unless you have a high pinion front, this is only true for the rear axle.
04 LJ 4.5 RE SF w/ 3.5 springs 32x11.50R15 BFG MT 4.88, Lock Right F/R [SIZE="2"][COLOR="Red"]Red Jeep Club Member #347[/COLOR][/SIZE] |
#54 | |
Yea that way if the strap breaks you have about 6 lB flying back at ya instead of just the 2 lb hook. Under pull that hook is not going to slip off the strap.
#55 |
likewise with the AW4 four speed auto. 2.804 in first, 2.393 in reverse.
-Shawn |
#56 | |
If you compare the size of the hook to the amount of strap it is supposed to contain you will note that it is normally difficult (at best) to get the spring latch on the hook to securely hold both of the loops. This often results in a choker type rigging that is known to be weaker than the basket type and therefore has a greater chance of breaking. The use of the shackle allows the tree strap loops to both be linked to the hook without resorting to a choker rig or to having one of the loops only partially contained in the hook (I have also seen hooks pierce the straps because the loops were not being fully retained in the hook, this is bad and resulting in a weak point in the strap loop, requiring strap replacement.). If a tree strap should break the strap itself will tend to slow the shackle and hook as the strap unwraps around the tree. In any case accepted winch practice includes something over the cable so that if something breaks the amount of damage is (hopefully) reduced. Most winch incidents due to tow point failure seem to result in the cable recoiling only slightly and falling to the ground (along with the bumper/trailer hitch etc). Full load cable failure seems to result in the cable whipping. The result if this can be loss of limb and life. Cable failure is normally due to lack of inspection and maintenance or by jerking on the cable (i.e. the vehicle being winched tries to climb the obstacle, makes slack in the cable then drops back with a jerk). (A winch is not a snatch strap and should not be used like one). Feel free to do it your way but I believe mine is safer. Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway. Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road. Last edited by Happy Joe; 02-25-2008 at 11:08 AM.. |
#57 | |
__________________ In Memory
"Lets Roll" |
#58 |
i dont know what my chain is rated for because i found it on the side of a road, but i do know the links are bigger than any other chain i've seen.
joey, my comment about the gearing in reverse was mainly about my tranny (AX-15). i didnt know anything about the 6 spd, but now i do. thanks
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts [url]http://www.cardomain.com/ride/2634280[/url] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
