Quantcast recovery NO NO? - Page 3 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > recovery NO NO?
Old 02-19-2008, 03:55 PM   #31
chrisjep97
http://www.quadratec.com/products/92144_600.htm
http://www.quadratec.com/products/92121_50.htm
those are what i use.................
hang a jacket on the cable/strap when using it so it can dampen the shock if it breaks,while pulling or winching (so nobody gets killed). youtube.com has some good vids, like the ones previously posted.
chrisjep97 is offline   Reply With Quote
Old 02-19-2008, 04:20 PM   #32
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
http://www.southernhighrollers.com/tips/articles/a_near_miss_from.htm
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline   Reply With Quote
Old 02-19-2008, 04:37 PM   #33
GCJoe
I unfortunately have a strap with the hooks on the end of it. I bought it years ago before I knew better. What do you think about cutting the hooks off and leaving the loops? They'd be small, but should be functional.
GCJoe
2001 XJ
Bone Stock
GCJoe is offline   Reply With Quote
Old 02-19-2008, 04:41 PM   #34
chewTJ
Dang!
[JEEP]
OllllllO
Blue jeep club member #248Low output Jeep club member #279MN jeeper member #3
Originally Posted by BlackBellamy View Post
...now hush, I'm off to install a throttle body spacer and a K&N filter for that super performance boost!
chewTJ is offline   Reply With Quote
Old 02-19-2008, 04:42 PM   #35
msavard
I bought my 30k military Suprplus strap off ebay (new) for $30 or so... I have another 20k strap that 4 Wheel Parts donated to our club as well. A good strap shouldn't cost a ton of cash.
2004 Yellow TJ Sport
(purchased stock on 6.3.06)
4.0L Auto • 35" Maxxis Bighorns • D30/D44 w 4.88 Gears • 2.5" OME LJ/XJ lift • JKS Trackbars • Brown Dog MML • 1" BL • Warn Engine Skid • Aussie Locker (FR) / Rubi Air Locker (REAR) • SYE/CV • Nth Adj Control Arms • Bestop Oversize Tire Carrier • PSC Rocker Knockers • ORO Swayloc • TNT Tube Fenders
MIDSOUTH JEEP CLUB > Jeepers from TN, AR, MS, and KY
msavard is offline   Reply With Quote
Old 02-19-2008, 04:44 PM   #36
msavard
Originally Posted by chewTJ View Post
Dang!
THAT is why some folks will raise their hood up when pulling someone out backwards.
IMHO I don't like the act of pulling people out backwards... but if you are going to that's not a terrible idea (as long as you have someone spotting the recovery properly so you know what's going on.
Old 02-19-2008, 04:58 PM   #37
badoosh27
your gearing makes for more torque in reverse, so its a pretty good idea...
make sure the vehicle you're towing can handle it too!!
case and point: http://youtube.com/watch?v=LTHnqB7w3cA
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
[url]http://www.cardomain.com/ride/2634280[/url]
badoosh27 is offline   Reply With Quote
Old 02-19-2008, 05:44 PM   #38
mschviuz
Jeepin Down South
mschviuz's Avatar
Wow..that sux
mschviuz is offline   Reply With Quote
Old 02-19-2008, 05:44 PM   #39
MoJeeper
I would like to know why my club insist on using a shackle between the winch hook and tree saver. Why cant I hook the hook straight to the strap? Why to I want to add 4lb to the mix when I'm winching? Also why is when I'm jeeping people insist on having the scew shackle verses one with a quick pin, when every other job i've been on a quick pin one works just fine.
99 Green TJ SE
3" Full Traction Lift
4.88's, 33" MT's
My Jeep
MoJeeper is offline   Reply With Quote
Old 02-19-2008, 06:03 PM   #40
Andrew F
It sounds like it is two parts vs three parts if it is the same shackle I am thinking of.
04 LJ
4.5 RE SF w/ 3.5 springs
32x11.50R15 BFG MT
4.88, Lock Right F/R
[SIZE="2"][COLOR="Red"]Red Jeep Club Member #347[/COLOR][/SIZE]
Andrew F is offline   Reply With Quote
Old 02-19-2008, 06:24 PM   #41
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
i have both a recovery strap and a chain. a ton of people hate the idea of using a chain, but my chain is darn near unbreakable. i know they can break, but the odds of my little TJ making enough force to break it is zero. i used it with my old K5 Blazer to pull down trees, pull out stuck people, and all kinds of stuff and have never had a problem. i would trust a chain waaaaay more than the cable on a winch even. i'm not knocking straps, but i like my chain. plus its about 40 feet long and can reach much farther than any strap i've seen.
What is the load rating of your chain?
We save dogs: http://www.secondchanceshepherds.org/
JBWood05TJ is offline   Reply With Quote
Old 02-19-2008, 06:24 PM   #42
mschviuz
Jeepin Down South
mschviuz's Avatar
good videos
Thanks for the links and the info....i'm sure more info is to come.
I'm not qualified to launch missiles and therefore didn't want to put any hooks into orbit. I'm glad I got this thread going and thanks for the info added
Old 02-19-2008, 06:26 PM   #43
JBWood05TJ
JBWood05TJ's Avatar
Originally Posted by djt283 View Post
If the second vehicle doesn't have shackles, you can just loop the strap around a good recovery point, then loop it through itself. Then pull the other end over to your vehicle with the shackles and get unstuck. No nots to untie.
Just understand that choking a sling like that reduces the rating of the sling by about a third or a half vs. a straight line pull. If the sling is long enough, better to hook one loop to an attachment point on the recovery vehicle, run the sling around the bumper of the recovered vehicle, and back to the recovery vehicle with the other loop at a second attachment point.
Old 02-19-2008, 06:36 PM   #44
Kiwi Jeeper
Yes, but what about the strength of teeth on your diff gear set. They are cut with the view that they would be strongest when pulling in the forward direction (your normal direction of motion). I have seen diff gearing being destroyed while pulling in reverse direction.
Kiwi Jeeper is offline   Reply With Quote
Old 02-19-2008, 06:58 PM   #45
IslandTJ
Drink Oregon Craft Beer!
IslandTJ's Avatar
Location: where I wheel: N 45Ί 36.663' W 123Ί 20.935', Oregon
...a ton of people hate the idea of using a chain, but my chain is darn near unbreakable...
A chain does have its use in recovery; however unlike a snatch strap, there is no elasticity (kinetic energy) to take advantage of within the linking device. I can see a chain working to anchor a feasible recovery/mounting point.
A chain may even extract the struck vehicle, however there should be NO JERKING OR SUDDEN pulls.
Yes, the chain can be tougher than the jeep - to the point of breaking an axle, recovery point or even your motor mounts. Caution is strongly encouraged!
Jeep safe, Jeep hard!
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
  • Self Recovery ????? - General Jeep & Off-Road Equipment (5 replies)
  • Recovery 101 - General Jeep & Off-Road Equipment (9 replies)
  • Recovery - General Jeep & Off-Road Equipment (15 replies)
  • recovery bag - General Jeep & Off-Road Equipment (12 replies)
  • Recovery - General Jeep & Off-Road Equipment (34 replies)
Glock Forum
