#1 | |
Jeepin Down South
recovery NO NO?
Ok....not sure where to post this but since I have a TJ I'll try here.
I've read posts that say you aren't supposed to use tow straps with metal hooks and I can use my imagination to figure out the why but..... what is the correct way to use a recovery strap? any pics? I'm new to 4 wheelin and would like to see the correct ways before something goes majorly wrong!
#2 |
If a strap with a metal hook lets go, a large hunk of metal goes flying through the air causing the obvious safety issue. If a loop strap breaks, the idea is that there is no chunk of metal attached to it.
02 TJ Sahara, 2.25"BB + 1.25" BL, 32" Maxxis Bighorns |
#3 |
Jeepin Down South
Yea...that's what I meant by i can imagine the reason not to use hooks. What I want to know is how are you tieing the loops without them tightening up so much you can't get them off
#4 |
I wonder if there's been a thread on "recovery techniques"? That would be cool. I think the main rule is to hook to something capable of taking the jerk and just use your imagination depending on the circumstances. Personally, I think an axle would be the best point of hookup-but it's likely seldom available. I also read there are minimum hook points required on a rig before you're allowed on certain trails. Tying loops is better done with proper knots like a sheepshank and bowline. There are also special knots used for straps and slippery material. Just remember, knots on average weaken the "rope" by half.
My jeep makes a ticking noise too It has done it since it was new I couldn't care less- I must confess I use FRAM filters too! |
#5 | |
Jeepin Down South
#6 |
Are you serious?
Any strap has a loop on each end. Put the loop through the D rings on your rig... no need to tie anything.
2004 Yellow TJ Sport
(purchased stock on 6.3.06) PICTURE 4.0L Auto • 35" Maxxis Bighorns • D30/D44 w 4.88 Gears • 2.5" OME LJ/XJ lift • JKS Trackbars • Brown Dog MML • 1" BL • Warn Engine Skid • Aussie Locker (FR) / Rubi Air Locker (REAR) • SYE/CV • Nth Adj Control Arms • Bestop Oversize Tire Carrier • PSC Rocker Knockers • ORO Swayloc • TNT Tube Fenders MIDSOUTH JEEP CLUB > Jeepers from TN, AR, MS, and KY |
#7 | |
Jeepin Down South
I didn't think of that because I tightened the pin down so it wouldn't come off on the road. I just need to keep a crescent wrench in the jeep. ![]() Anyway to delete this entire thread so the jeep world doesn't think I'm completely stupid...I swear...I'm not. LOL! |
#8 | |
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more "If you aim at nothing, you will hit it every time." — Zig Ziglar |
#9 |
#10 | |
Little tip on the shackles... I keep my torqued down as well... Just use a screwdriver (or anything with a tip that will fit through the hole) through the hole at the end of the pin to gain leverage to twist it.... get a lot of leverage that way. Congrats on being smart enough to seek out the proper way to recover a vehicle instead of just winging it and risking injury/damage.
#11 |
Get on youtube and search for "4x4 recovery".
I had 6 pages pop up. I watched one the other week that was great. If you use shackles/metal all you have to do it loop a safety strap round the hook/metal side so that if it goes flying, the small safety loop/rope will catch it and kill all its energy. Some Aussie cats did the video, it was great. It was like a whole series. Nevermind, I went and found it for ya This video should be something everyone that signs on to the forum should watch
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s |
#12 |
Jeepin Down South
thanks guys, I'll check those vids out when I get home. can't pull up youtube and some other vid sites here at work(blocked)
#13 |
snatching with rope=
![]() (in my case )
lx015oɹd uǝpıun 'ɥɔuıʍ ql0009ɟɥ ؛ɹǝıɹɹɐɔ ǝɹıʇ pol 'sɹǝpuǝɟ ǝqnʇ pǝɹɐlɟ"5˙4ʇuʇ :˙ɔsıɯ ؛sɹǝpıls sʞɹoʍʞɔoɹɥs 'pıʞs ǝuıƃuǝ ɔıpǝɯdǝǝɾ 'pıʞs ɹoʇɐıpɐɹ s,ʎʇsnɹ 'ʞuɐʇsɐƃ puɐ xoq ƃuıɹǝǝʇs ʇɥƃıɹuǝƃ :spıʞs ؛pɐoɹɟɟo ɹoɟ sɹǝƃƃoq"53 'ʇǝǝɹʇs ɹoɟ s,ʇ/ɯdɯoɔoɹd"53 :sǝɹıʇ ؛lɯɯ"1 'lq"52˙1 'spq "2 :ʇɟıl ؛ɹǝʌoɔ uǝɯʞoɹ 'loods-ıuıɯ 'sǝʞɐɹq ɔsıp 'sʎollɐ ɥʇıʍ 44p ؛ɹǝʌoɔ ɹǝɥsnɹɔʞɔoɹ 'slɐǝs ǝlxɐ ɹǝʇno 'ɹǝʞɔol ǝıssnɐ 'sʎollɐ /ʍ 03p '6ı :ɾʇ,00 44p '03p '6ı :5ɾɔ,37 s,ʇ/ɐ ƃɟq"23 '44p '03p '8ʌ063 :5ɾɔ,47 The Swamp Things 4x4 Club Jeep Talk HomeGrown Offroad |
#14 |
Good video.
Air Force Jeep Club - Tail# JF037AD '03 TJ Sport, Black on White, Stock. [[Gone]] '99 XJ, Purple, Stock but with new wheels. Running Doorless? Check your state's Mirror Laws!! http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/ There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else. Theodore Roosevelt |
#15 |
i have both a recovery strap and a chain. a ton of people hate the idea of using a chain, but my chain is darn near unbreakable. i know they can break, but the odds of my little TJ making enough force to break it is zero. i used it with my old K5 Blazer to pull down trees, pull out stuck people, and all kinds of stuff and have never had a problem. i would trust a chain waaaaay more than the cable on a winch even. i'm not knocking straps, but i like my chain. plus its about 40 feet long and can reach much farther than any strap i've seen.
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts [url]http://www.cardomain.com/ride/2634280[/url] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
