#1 | |
Recovery Help....
Ok, there's a lot of options out there but most of them scare the crap outta me thinking about using them. So I thought I might give you guys my scenario and maybe you can help me out and point me to some products.
First off, I'm not yet able to affor a front bumper with recovery options so right now my scenario is a rear hidden hitch with a D-Ring attached to that.... Basically, what should I buy to pull my stock XJ outta the mud if I get stuck? I've seen chains, kinetic rope, straps, but which is what I want and which is safest? I won't be in mud deeper than a foot or so, so I won't need the doomsday setup LOL. Basically something I could wrap around a tree behind and pull me out. Thanks for all your help!
[CENTER][COLOR="Wheat"]1999 XJ Sport 4x4 ~~ Desert Sand w/Grey Interior 4.0L HO Inline 6 ~~ 235 Bridgestone Dueler APT's on Stock Rims [URL="http://pages.suddenlink.net/jeremymayle/jeep/jeep.html"]My XJ's Gallery[/URL][/COLOR][/CENTER] |
#2 |
Do it right or not at all
![]() Join Date: Jan 2003
I can offer nothing manual that I'd use, including come-alongs, Hi-Lift, etc. to extract me. Both offer too much work and not enough "get-me-out". It's best to carry a hookless snatch strap and NEVER wheel alone. Have the other guy pull you out.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#3 |
I have only been wheeling for a year. I have used recovery straps all except one time. And that includes the time I got stuck in mud up to my rock panels. If you look around online, you can get a decent recovery strap for about $40.
Anything that is metal, like chains and straps that have hooks instead of eyelets, stores kinetic energy and will fly back if something breaks. That is when someone gets hurt.
'00 TJ 4.0L 5 Speed D30/D44 UNlimited Slips Diffs 31' BFG Mudders on Cragar Soft 8's ARB Snorkel - Hand Throttle - XM Radio |
#4 |
I use hookless straps (hooks suck)and my winch and ive been thick in mud past my doors..
Going by yourself is risky I got a call at 1030pm to do a rescue for a friend who wanted to impress hsi buds with his ranger .. It rained HARD maybe 2 inches in 30 minutes and they were all stuck couldnt go any farther and no way to get back from where they came from.. Easiest thing is to get yanked back where ya came from Ive been up against a wall of dirt and didnt realize it You cant really tell but my drivers side bumper is totally bent and my tow hook is bent up the bolt went through the frame from a 3/4 ton Ram Diesel trying to get me out when I was against a wall and didnt realize it we were using 6 inch thick straps to try to get me out.. ![]() This one the whole ground was cracked so I figured it was dry.. ![]() I knew this hole was here but I slid into it Its over 49inches deep now (watched 49s go under going through it) Also have hitch connected to D ring ![]() Same hole point is make sure you knwo how deep it is or you could go swimming ![]()
05 LJ RE 4.5 SA 1inch BL Aussie front Detroit rear 4.88s 1200 series Tractor tires (37x10) Warn winch stinger Lotsa trail damage Last edited by dawnskaybug; 08-29-2007 at 04:17 PM.. |
#5 | |
#6 |
My hoods up when I winch and im clear outta the way
05 LJ RE 4.5 SA 1inch BL Aussie front Detroit rear 4.88s 1200 series Tractor tires (37x10) Warn winch stinger Lotsa trail damage |
#7 |
Thanks everyone! Chain may be the cheapest way to go (and safest) do you have any links where they sellem with hooks? Thanks!
#8 |
Whatever you do when you buy chains, make darned sure they are 'Rated' at the loads you will be placing on them. Common run-of-the-mill chains like are sold at Home Depot and hardware stores are not normally Rated. Like the difference between a Grade 5 or Grade 8 bolt and a common non-rated bolt, there's a huge difference in strength. You never want to use an unrated chain for recovery purposes.
Most sources of recovery equipment sell rated chains with hooks on the end. I can post the URL of one later tonight if needed. Warn (and most other mainstream winch manufacturers) sells them but you may have to buy an entire kit which has the chain, shackles, straps, snatch-block etc. in a carrying bag.
#9 | |
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#10 |
Thanks for the clarification Jerry. I had some miss-information.
#11 |
i got a 20,000lb tow strap off ebay for like $25 and i have used it many a time and it has never failed me. about the whole chains thing, my buddy got his rear window shattered when he was trying to tow someone out with chains, so they are not 100% safe.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
