Rear Tire carrier without a receiver hole - JeepForum.com
post #1 of 6 Old 05-22-2010, 06:55 PM Thread Starter
BeerNut0875
I have an 04 with a receiver hitch on it with a stock bumper. I am looking for a tire carrier/bumper without a receiver hole on it. Does anyone know of a brand to look at? I want to keep my receiver as I pull a trailer, and do not want to use bumper pull. The only think I can find is bumpers with a receiver slot.
BeerNut0875 is offline
post #2 of 6 Old 05-22-2010, 09:34 PM
dwilliams35
Just wondering: Why? If the bumper's built to take it, is there any reason why not to just go with a bumper with a receiver? You end up with a better departure angle and it just simply looks better IMHO: A lot of the bumpers out there are built stronger than any receiver hitch on the market...
dwilliams35 is offline
post #3 of 6 Old 05-22-2010, 11:24 PM
RogueSpear2023
I also have to ask why? Get a bumper with a receiver hitch that is rated for towing, and get frame tie ins. It will be much stronger the receiver hitch, and you won't loose ground clearance either.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 6 Old 05-23-2010, 08:44 AM Thread Starter
BeerNut0875
Because most tire carriers are only rated to carry accessories, and have no tow rating. I need to be able to pull a utility trailer loaded.
post #5 of 6 Old 05-23-2010, 09:21 AM
JIMBOX
Not sure thaT they make one for the '04, but I have an OLYMPIC "rock" bumper front and back and the front has a receiver hitch, but the rear is just clean and clears the jeep hitch
I got mine from 4WD.com for about $270 bucks
Checkemout
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #6 of 6 Old 05-23-2010, 09:46 AM
dwilliams35
What you've got here is simply a matter of certification: Jeep bumper manufacturers aren't going to spend the wad of money to get an SAE J684 certification on their equipment, so they just rate them for accessories, which doesn't require any certs... They could be 20x stronger than a standard receiver hitch and still wouldn't get the rating.. The bumper I got way back when even has tow-chain attachment points, but when I asked the manufacturer about trailer towing ratings, they basically told me yes,off the record it'd pull anything the Jeep could pull, but they couldn't legally tell me X rating.. It's up to you, but I personally don't have any problem with using it for that. (I also pull trailers with bumper-mounted hitches I've made myself: they don't have an SAE rating either...) Your call, of course, but as long as I knew it was a very substantial bumper, I wouldn't have much of a problem with it: it's not like Jeeps are going to be pulling any 10,000 lb. trailer anyway: anything you'd pull is piddly compared to what most of these bumpers could handle..
Truetrac carrier ring gear bolt hole size problem D35 rear Blk2kTj Engines & Drivetrain 2 08-16-2007 10:15 AM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
2" receiver tire carrier Runnerboy Tires & Wheels 13 01-19-2006 08:55 AM
rear tire carrier Tri_X_Troll Fabrication Shop 3 10-30-2005 08:08 PM
New Tire Carrier Hinge...now to cut the hole Scafone Fabrication Shop 5 04-01-2005 08:12 PM
