rear shocks - JeepForum.com
post #1 of 3 Old 11-17-2011, 07:49 PM Thread Starter
03wranglerX-man
rear shocks
Looking for help with replacing my rear shocks. Big job? Special tools required, if any? Recommended options?
03wranglerX-man is offline
post #2 of 3 Old 11-17-2011, 09:59 PM
Wrangler_91
Nope, not really a big job at all. In fact, I did it in the dorm parking lot my freshman year because that was the only place I had. Only issue you could really run into is that the lower bolts supposedly have a tendency to shear/twist the heads off. In which case your stuck extracting the remainder of the bolt. I recommend soaking the bolts in pb blaster a day or two before doing the job, depending on the amount of corrosion.
Wrangler_91 is offline
post #3 of 3 Old 11-18-2011, 05:45 AM
tjwrangler99
the only pain is rusty bolts... soak em in PB blaster for a bit before the job, they should come out. I had to replace mine with new hardware due to destroying a few... but i also have a 99 that was originally from NJ so theres some rust.
1999 TJ
BFG AT 31's | BDS 2" Lift | JKS Quick Disco's | Zone Rear Sway Links | TeraFlex 1/2" Drop+Washer | Warn M8000 | Viking 80' 3/8 Synthetic w/ Safety Thimble | Viking 350 Fairlead | MetalCloak AL Bumper | 99 Durango Steering Box | Uniden 520 CB w/ 3' FireStik | ebay header | Magnaflow Mid-Cat | Banks Cat-back | XJ Steering Linkage | Hella Black Magic (x4)
2011 Patriot FD1
tjwrangler99 is offline
