Rear mounted tow hooks - JeepForum.com
post #1 of 8 Old 05-06-2001, 05:15 PM Thread Starter
jeepnmad198
I have a 95 YJ and I was looking into going to some events this summer but to enter you need tow hooks front and rear, Where do you mount them in the rear. I don't see a good place for them. Thanks for all the help.
1995 YJ (0lll0) Spring over, 33" Swampers.
jeepnmad198 is offline
post #2 of 8 Old 05-06-2001, 08:11 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Get a rear bumper with tow points like this one from Tomken
Tomken
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 8 Old 05-07-2001, 12:23 AM Thread Starter
jeepnmad198
That would not be a problem if I had $200 just laying around... but that is not the case.
post #4 of 8 Old 05-07-2001, 03:27 AM
horatio102
If you've got a 2" receiver hitch you can get a $20 shackle for it. Warn makes them... big ring on a 2" post. That'll qualify as your rear tow point.
horatio102 is offline
post #5 of 8 Old 05-15-2001, 09:59 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
What a member of our club did was pull off the bumperettes, and mount a 3ton clevis holder to a 1/4" plate of steel .. and mount back into the holes again .. did it to both sides .. cost was the clevis ($10 each), the 3ton holders ($35 each), and the steel plates .. a bit of time .. and new bolts. Looks good .. and extremely strong!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #6 of 8 Old 05-16-2001, 02:50 PM
gotjeep
Some TJ's come from the factory with a frame mounted rear tow hook. Just a couple of holes to drill.
Those can't be more than $30.
Scrappy 2000 TJ
gotjeep is offline
post #7 of 8 Old 05-16-2001, 03:19 PM
gotjeep
Found two pictures.
Good Luck!
Scrappy 2000 TJ
gotjeep is offline
post #8 of 8 Old 06-13-2001, 12:11 PM
keithTJ
keithTJ's Avatar
I drilled holes in my TJ rear bumper, then placed the tow hooks on the bumper. I drilled the holes for the hooks a couple of inches a way from the bolts mounting the bumper to the frame. Make sure the tow hooks are inside of the bolts mounting the bumper to the frame. I was told that was the strongest part of the bumper. It has worked for me numerous times.
keithTJ is offline
rear mounted raditor PilotMan Engines & Drivetrain 3 02-08-2010 07:26 AM
Anyone have a rear mounted amp? 97 TJ jhh Audio, CB & Ham Radios, GPS, & Electrical 15 02-03-2009 09:52 AM
hard mounted tow hooks Trebor General Jeep & Off-Road Equipment 6 01-23-2008 08:47 AM
Pics of mounted clevis hooks D-rings?? jrodum Fabrication Shop 2 09-18-2007 09:42 PM
Rear tow hooks sgtoobie Cheap Tricks & Fixes 4 08-25-2006 12:04 PM
