-   General Jeep & Off-Road Equipment (http://www.jeepforum.com/forum/f27/)
-   -   Rear mounted tow hooks (http://www.jeepforum.com/forum/f27/rear-mounted-tow-hooks-13997/)
jeepnmad198 05-06-2001 06:15 PM
I have a 95 YJ and I was looking into going to some events this summer but to enter you need tow hooks front and rear, Where do you mount them in the rear. I don't see a good place for them. Thanks for all the help.
FLHT_FXRS_YJ 05-06-2001 09:11 PM
Get a rear bumper with tow points like this one from Tomken
http://www.tomken.com/partpics/large/tmr-0719-b.jpg
Tomken
jeepnmad198 05-07-2001 01:23 AM
That would not be a problem if I had $200 just laying around... but that is not the case.
horatio102 05-07-2001 04:27 AM
If you've got a 2" receiver hitch you can get a $20 shackle for it. Warn makes them... big ring on a 2" post. That'll qualify as your rear tow point.
NaeKid 05-15-2001 10:59 PM
What a member of our club did was pull off the bumperettes, and mount a 3ton clevis holder to a 1/4" plate of steel .. and mount back into the holes again .. did it to both sides .. cost was the clevis ($10 each), the 3ton holders ($35 each), and the steel plates .. a bit of time .. and new bolts. Looks good .. and extremely strong!
gotjeep 05-16-2001 03:50 PM
Some TJ's come from the factory with a frame mounted rear tow hook. Just a couple of holes to drill.
Those can't be more than $30.
gotjeep 05-16-2001 04:19 PM
Found two pictures.
http://www.pcc.net/gotjeep/images/reartowhook_001.jpg
http://www.pcc.net/gotjeep/images/reartowhook_002.jpg
Good Luck!
keithTJ 06-13-2001 01:11 PM
I drilled holes in my TJ rear bumper, then placed the tow hooks on the bumper. I drilled the holes for the hooks a couple of inches a way from the bolts mounting the bumper to the frame. Make sure the tow hooks are inside of the bolts mounting the bumper to the frame. I was told that was the strongest part of the bumper. It has worked for me numerous times.
The time now is 07:25 PM.
