question on straps to hold back window up - JeepForum.com
post #1 of 2 Old 05-28-2012, 06:06 PM Thread Starter
daphney
I lost one of the vinyl lanyards that snap on to the top and have a loop to loop around the back window when you roll it up. Several jeep part retailers have no idea what I'm talking about. I have a 2011 four door wrangler. Does anyone know of the straps I'm talking about, and where I could purchase one???
daphney is offline
post #2 of 2 Old 05-29-2012, 05:06 AM
Faramir66103
The straps on my TJ soft top are elastic with snaps and over time have gotten stretched out. I just ended up tying a couple 2(ish) foot lengths of 550 cord around the soft top frame with a clove hitch so that each end hangs over the rear window when it's rolled up. I can then easily tie a bow knot around the rolled up window and be good to go. After a while of running that way I tried out some small Nite Ize Figure 9 rope tensioners. They are quite ingenious and simple to use. I've permanently tied two of them into the rear window cords, and they are even faster and easier to use than before. I'm stuck with the hard top for now, or I'd take some pics for you all, but I'm guessing you can use your imagination
Cheers,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
Rear passenger window on WJ won't roll back up thatoneguyaz Audio, CB & Ham Radios, GPS, & Electrical 3 01-02-2012 02:34 PM
Help, broke straps that hold rear driveshaft u-joint to axle yoke Xj97offrd Engines & Drivetrain 8 06-01-2011 07:04 PM
Zipper broke on back window Matty4x4 Cheap Tricks & Fixes 6 11-22-2010 09:23 AM
Question about Soft Door Window Equipment jamma007 General Jeep & Off-Road Equipment 0 10-10-2010 06:03 PM
Broken back window zipper WT427 General Jeep & Off-Road Equipment 1 04-20-2009 03:44 PM
