question about diff front and rear axle ratios - JeepForum.com
post #1 of 9 Old 12-30-2007, 08:38 PM Thread Starter
90XJPIONEER
1990 XJ Cherokee
if the 2 axles are diff ratios, how do they not spin at diff speeds?
if one was 3.55 on the front, and rear is say 3.07, wouldn't the tires always be spinning at diff speeds?
'90 XJ Pioneer 4.0 - AX15 - 2WD - Dana 35 - Skyjacker 3" Lift - YKS 32" ATs
90XJPIONEER is offline
post #2 of 9 Old 12-30-2007, 08:51 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
short answer...Yes..
Some competition mud boggers use a different ratio in the front to increase wheelspin over the rear to help keep it straight down the lane..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #3 of 9 Old 12-30-2007, 09:23 PM
Crashnburn80
Crashnburn80's Avatar
If your axle ratios are significantly different, such as 3.07 and 3.55, your Tcase will eventually blow (or some other driveline component) when using 4 wheel drive.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #4 of 9 Old 12-30-2007, 09:31 PM Thread Starter
90XJPIONEER
1990 XJ Cherokee
any idea what it is on the stock XJ?
off the factory, do they come the same?
post #5 of 9 Old 12-30-2007, 09:56 PM
jp360cj
1977 CJ7
not sure about what came stock, but they would have to be the same.
I have seen hardcore trail rigs run different gears front and rear to compensate for different tire sizes. Not sure why they didn't use the same tire size though.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is online now
post #6 of 9 Old 12-30-2007, 10:34 PM
chadsmeltzer
chadsmeltzer's Avatar
Most of the time, they are very close, but not the same. Ex. 4.10 with 4.11
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #7 of 9 Old 12-30-2007, 11:03 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
If the front and rear have different sized ring gears you will have slightly different ratios. If you have a D44 front and rear, you will likely have the same ratio.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #8 of 9 Old 12-30-2007, 11:23 PM
mylt1
mylt1's Avatar
XJ's with auto stock is 3.55. you have a 2wd posted are you getting a 4wd or gonna convert the 2wd to 4wd?
mylt1 is offline
post #9 of 9 Old 12-30-2007, 11:54 PM
taseal
1993 XJ Cherokee
it was actually me posting from my bud's account cuz I was over at his place...
he doesn't need to worry about this, its me who was actually curious
'93 Cherokee "XJ" Sport - 4.0 HO - 4x4 - AX15 - Chrysler 8.25 - Fun Jeep
'08 Patriot "MK" Limited - 2.4 - 4x2 - CVT II -DD Jeep
taseal is offline
Mathcing front & rear axle ratios? atomicjoe23 Engines & Drivetrain 14 08-14-2009 10:46 AM
front and rear axle swap metallica0682 Engines & Drivetrain 1 04-14-2009 04:06 PM
will front locker save rear axle. AFcanyon Engines & Drivetrain 4 12-26-2008 12:48 PM
Rear Axle Swap=Front as well??? LeeV Engines & Drivetrain 9 12-28-2007 04:15 PM
Any diff between rear and front AAL's? 91yjeeper Tires & Wheels 5 08-10-2004 08:01 PM
