protecting brakes and calipers while offroading/mudding - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > protecting brakes and calipers while offroading/mudding
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 08-29-2015, 09:30 AM   #1
Jordan_goneJ339
So the last couple times i was offroading/mudding in my 2000 wj and get all sorts of stuff stuck in my calipers that start scratching and making noises. A few days ago i bent the back rotor cover thing and had rocks stuck in there scraping and i really dont want to cause damage to my braking system. Is there a type of cover for brakes? I image it also has to do with rims, i notice many offroading rims are mostly covered on the outside, unlike the stock rims that have large openings to the brakes. I though about trying to make some type of cover that goes on before the wheels go on to protect them but id like to have other peoples 2 cents on protecting the brakes.
Jordan_goneJ339 is offline   Reply With Quote Quick reply to this message
Unread 08-30-2015, 06:00 PM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Don't worry about them, they're not going to be harmed by trail debris. Hose them off real good, straighten the sheet metal brake shields if necessary, or pull the calipers/pads and clean them if a piece of grit got caught between the pad and rotor and is screeching, but I wouldn't do anything or worry about them beyond that.
Just keep in mind that the pistons in the calipers might wear prematurely which can make them stick but there's no protective brake cover available or different wheel design that's gong to significantly reduce the amount of mud/debris/dirt getting past them and into that area.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:57 AM   #3
Jordan_goneJ339
Alright thanks! I guess im just worried too much.
