Price for Axle Seal Replacement? - JeepForum.com
post #1 of 6 Old 09-05-2009, 06:07 PM Thread Starter
GA95YJ
Has anyone recently had an axle shaft seal replaced by a shop? I'm just wondering what the average price would be.
GA95YJ is offline
post #2 of 6 Old 09-05-2009, 06:20 PM
jbramble24
Front or rear? I was quoted $210 for the labor for my front inner axle seal. I needed another excuse to regear so I am having it done at the same time and the regear labor is only $250.
GM 350 Powered 1984 CJ-7
jbramble24 is offline
post #3 of 6 Old 09-05-2009, 06:25 PM Thread Starter
GA95YJ
yes its the front on the passenger side. It's a D 30
GA95YJ is offline
post #4 of 6 Old 09-05-2009, 06:44 PM
jbramble24
That's the same one that is leaking on my D30. If you don't mind pulling the carrier out of the diff, you can do it yourself. Or so I've been told. The seal itself is only around $10.
post #5 of 6 Old 09-05-2009, 06:47 PM Thread Starter
GA95YJ
i've heard that you have to pull the diff carrier but i have also been told by some that you don't as long as you remove the vacuum disconnect housing. I'm just not sure if i am mechanically inclined enough to do this myself, or even have the required tools.
GA95YJ is offline
post #6 of 6 Old 09-05-2009, 07:16 PM
jpfelix
i just had both ends and the pinion seal replaced. ~$200
jpfelix is offline
TJ t-case front seal replacement help Muddeprived Engines & Drivetrain 1 06-18-2016 05:38 AM
Inner Axle Seal Replacement Skeezer Engines & Drivetrain 2 07-02-2008 07:11 PM
Valve stem seal replacement. scott wynn Engines & Drivetrain 2 06-11-2008 07:55 AM
Whats a fair price to Pay for a rear seal installation ScotZ Engines & Drivetrain 4 10-27-2005 07:27 AM
Timing cover seal replacement 89YJmoneypit Engines & Drivetrain 6 10-08-2003 05:12 AM
