Poison Spyder Hood Louver Install - Page 6 - JeepForum.com
post #76 of 131 Old 04-08-2013, 11:44 AM Thread Starter
Carlos14
Originally Posted by Copperhead89 View Post
I don't mean to be the cloud on a sunny day here, but driving in a heavy rainstorm will mean a bunch of water pouring all over the engine. Water and electrical components don't play well together.
If you're driving in a rain storm, your engine will get wet. Even without the holes In your hood. I haven't had any issue with rain water at all.
It's not a serious concern of mine with the hood Louvers.
Luck Favours The Prepared
Carlos14 is offline
post #77 of 131 Old 04-08-2013, 12:17 PM
Awesome
We have a huge hole in the body right in front of the engine that lets air and, oh yeah, water in.
I also don't know of anyone who still has the rubber splash guard still attached. Mine fell off years ago. Your tires kick water (and everything else) up into the engine bay.
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #78 of 131 Old 04-08-2013, 12:21 PM
kjg26
kjg26's Avatar
Mine has a force field that protects the engine
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #79 of 131 Old 04-08-2013, 12:40 PM
eduardostewart
i've had mine on for a year i guess. though it doesn't seem to hurt anything i just would like to come up with something that didn't let water in every time it rained. i have no problem when i go off roading and what not, but since it's not my dd i'll probably just get a whole car cover for it to protect it from the sun as well.
eduardostewart is offline
post #80 of 131 Old 04-08-2013, 03:37 PM
TJDaveX
I Plastidipped my entire engine. It doesn't get wet from the HUGE HOLE underneath the Jeep. I'm not even worried about the little vent openings in my PSC Hood Louver.
TJDaveX is offline
post #81 of 131 Old 05-05-2013, 04:19 PM
JK_Driver
2010 JK Wrangler
Hey Carlos, someone mentioned using silicon caulk on it when it's installed, I read somewhere else about running some electrical tape along the inside, run it a little bit away from the edge and yes, it will cover the holes where the bolts go, but, you just push the bolts through it. The thought was that with the tape, then there is no metal to metal contact that does start corrosion, aluminum louver material against the painted metal hood. I have not ordered my PSC louvers yet, but, when I do and when I install, I might just run a 1 1/2" wide strip of electrical tape along the inside edges. Anyone have any thoughts on this and the possible rusting if not done? Nice Jeep by the way!!
2010 JEEP Wrangler Unlimited Sport 4 X 4 Soft Top with Auto Trans, Natural Green Pearl Coat
JK_Driver is offline
post #82 of 131 Old 05-06-2013, 12:00 PM
RowJ
I have noticed lower temperatures while on the freeway and on the trail.......... .
I have the 'Run Cool' Louvers. I ride with several that have Spyders.
Of the four of us that have discussed it.... none of us see lower coolant temps (at the gauge) on the hwy.
I still get a mild overheat running the A/C at hwy speed when it's over 80* OAT. No more nor less than before the louvers.
The biggest two advantages, IMO, are prevent overheating from long term idling and to reduce heat soak when shutting down in the summer. And possibly releasing heat to reduce air temp around the engine.... thereby causing cooler air to be sucked into the engine??
i love the look and do think they are worth the cost but.......If your having overheaing problems, don't count on much help from louvers.
RJ.
RowJ is offline
post #83 of 131 Old 05-06-2013, 07:01 PM
GilaMtnJeep
GilaMtnJeep's Avatar
RJ.
I have installed a PSC louver on my TJ. I did not see a big drop in engine temp. What I DID see was a BIG drop in under hood temps, around 40 or so. My heat soak is non-existent now, and I have actually seen the temp gauge move up and down between 200 and 210 when driving and running the AC has not effect. Before the louver install it would sit on a rock solid 210 all the time and even creep up to 215+ in traffic. So to me it was worth every penny.
The PSC louvers also have about 30-40% more venting than the Run Cool louvers do (judging by what they look like).
If you are experiencing any kind of over heating issues you may want to inspect your cooling system closely.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #84 of 131 Old 05-07-2013, 09:08 AM
RowJ
Off top of my head I wold argue your first point.
But since 'hole' sizes are not published, it's difficult to compare sq Inches of louver vents?
On second point - entire cooling system was replaced when I bgt this 98.
And a new 4.0L engine was installed 8,000 miles ago.
My only over heat condition is with A/C on, and since compressor is original....??
Also, many early TJ's (97-99) report overheating with A/C.
RJ
RowJ is offline
post #85 of 131 Old 05-08-2013, 06:18 PM
GilaMtnJeep
RJ
Wasn't aware of issue with the earlier TJ's and AC. Mine's an 03 and my issue was heat soak. After the louver install operating temp is right around 205 and heat soak is gone.
I though the PSC had more vent area based on the pics I saw as they run the length of the raised portion of the hood and also the area between the rubber stops. I do realize that it's only my humble opinion.
Top side
View from the bottom.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #86 of 131 Old 05-09-2013, 11:20 AM
RowJ
..I though the PSC had more vent area based on the pics I saw .... I do realize that it's only my humble opinion.
Great pics. And after seeing your pic from underneath, I suspect you may be right?
At risk of beating dead horse.... I would be interested in your measuring width of each vent hole and reporting # of holes.
I can do same.
People at 'Run Cool" claim serious research was done to design their location and shape for max cooling. That's why I bgt. their louvers instead of the cooler looking (no pun intended) PSC.
But, like everyone else, they also claim cooler coolant temps and possible HP gain from cooler intake air. So ..........??
Just coming up with comparison of sq. inches,while not conclusive, would be interesting, to me at least.
And I do have room to add other louvers, if more would be benificial??
RowJ is offline
post #87 of 131 Old 05-09-2013, 11:55 AM
GilaMtnJeep
I can do same.
I can measure when I get home later today and post up.
As for cooler temps, ok. But it must be defined. I definitely have cooler underhood temps, the heat is not trapped in there anymore. As for cooler intake air, maybe I guess. The intake horn is the front right corner so when moving I really don't see where there would be much, if any, reduction in intake air temps.
I also don't know about "cooler coolant temps" (t-stat opens at same temp louvers or not) but I could believe more efficient cooling. Before the install I would run rock solid at 210 in hot, cold, or any weather in between. In the summer in traffic 215 or so was the norm. After install I run right around 205 or so. The needle sits at the left edge of the 210 mark instead of right on it and will move a needle width back and for when driving, even in traffic. The heat soak issue I had is now non-existent.
The other nice thing about the louver is no more hood flutter at highway speeds. It isn't a "kite" anymore. Who knows maybe it even makes the brick more aerodynamic.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #88 of 131 Old 05-09-2013, 12:02 PM
RowJ
I'll measure tonight also!
EDIT: 07:00 - 14 louvers @ 7"; 4 louvers @ 6" = 122" total
RowJ is offline
post #89 of 131 Old 05-10-2013, 11:12 AM
GilaMtnJeep
I have 74 louvers at about 2-1/2 sq inches. Total is about 160-170 sq inches.
I did find the spec sheet for yours, they have it at about 120-125 sq inches of venting but you have room to add if you want more. If you look at it area wise, the equivalent area of coverage with the RunCool vents would be the same or even a little larger. Mainly because the RunCool vents are one at 6-1/2 or 7-1/2 inches long instead of two around 3 inches per row.
That said, depending on your set up, the RunCool vents could give you more space.
Now, where'd I put that crow recipe........
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #90 of 131 Old 05-10-2013, 12:22 PM
RowJ
Thanks for your calculations.
I had already edited my previous post...after measuring!
RJ
RowJ is offline
