-   General Jeep & Off-Road Equipment (http://www.jeepforum.com/forum/f27/)
-   -   Poison Spyder Hood Louver Install (http://www.jeepforum.com/forum/f27/poison-spyder-hood-louver-install-1463085/)
Carlos14 01-13-2013 02:18 PM
Okay, I have been gathering the pictures for this from my install over the Christmas break for college. A couple people have asked, so here it is, my install tricks and tips for the Poison Spyder Hood Louver.
Bare in mind, this is the YJ version, but I believe the tips will actually come in handy for other versions as well. Feel free to comment with any question, and post any tips you would also like to include once I'm done.
The Big Day:
I received this as a gift from my girlfriend this past Christmas. This was actually one of two Poisom Spyder gifts I had received from her, I know how to pick them;)
It was packaged very well and that was something that I was quite impressed with.
http://i1062.photobucket.com/albums/...91A3FF4F71.jpg
I was getting the urge to install so I ended up taking some Mother's aluminum polish to it which shined it up a bit.
Before pictures:
http://i1062.photobucket.com/albums/...0DD684F8AF.jpg
http://i1062.photobucket.com/albums/...0DE20D1F39.jpg
Carlos14 01-13-2013 02:19 PM
Install:
I finally made it over to my buddy's shop one day and we got to work. It was a busy day as I was also installing my Bombshell Diff cover, and doing other general maintenance.
http://i1062.photobucket.com/albums/...0DF935E353.jpg
We took the hood off and began to sand it down and remove the RUBICOIN decals. This part isn't necessary for the install, however I wanted to repaint the entire hood while I had it off the Jeep.
http://i1062.photobucket.com/albums/...0E06075C33.jpg
http://i1062.photobucket.com/albums/...0E09EBDDFB.jpg
As you can see in the picture above we lined up the provided template and stuck it on the hood. Mistake #1.
Tip: unless you want to spend hours removing the sticker template, do not stick it on, simply tape it down.
It is my understanding that not all the templates are stickers, regardless, tape works best.
When lining the template up, the footmans loops windshield tie-downs will be of great help. Keep them close by.
We drilled out the holes, following directions printed on the template. It is recommended that you use a hole saw for the large holes in the center. You will be cutting around this, so its not super important if they aren't perfect.
For cutting, we used a grinder, with a cut off wheel. I'm sure many other cutting instruments would work, but this is what we had on hand thanks to Anticanman for sending it to me!
If you take it slow, it worked extremely well and we only used one blade on the entire hood.
http://i1062.photobucket.com/albums/...0E0E0E15B6.jpg
http://i1062.photobucket.com/albums/...0E17591093.jpg
We also used a wire brush attachment to grind off any burs left hanging on.
There are about 40 bolt ones that go around the outside of the Louver. They are also marked on the template but for proper alignment, I suggest to save those for later.
Drill out the holes for the footmans loops and put those through.
To ensure correct alignment with your outer bolts, here is the biggest tip. Place the actual Louver on the hood, and put the loops through, then mark out your holes for drilling.
Once I had drilled out all the holes it went outside for a fresh coat of paint.
http://i1062.photobucket.com/albums/...0E1C20E2F6.jpg
Carlos14 01-13-2013 02:20 PM
After the paint dried, it was time to install.
I will say this, the Hood Louver itself is excellent, the mounting hardware included is not so much.
To save yourself a little time, I would recommend stopping by the nearest hardware store and picking up some hex head nut and bolts. Otherwise get your Allen wrench ready.
When bolting it up, we started with the loops and then did the outside bolts. For the most part, everything lined up well.
We reinstalled the hood and stood back to take a look!
http://i1062.photobucket.com/albums/...0E20A80ED0.jpg
http://i1062.photobucket.com/albums/...0E24AF25E4.jpg
http://i1062.photobucket.com/albums/...0E323F3C77.jpg
http://i1062.photobucket.com/albums/...C511EEAE0B.jpg
Carlos14 01-13-2013 02:43 PM
The After:
http://i1062.photobucket.com/albums/...C4E7942BB0.jpg
http://i1062.photobucket.com/albums/...C4FE921BBE.jpg
Over all I would say that I am very pleased with the look and function of the hood louvers. Before the install, I would often find myself sweating to the oldies while wheeling because I had to turn on my heater to get the engine to cool down a bit. The amount. Of heat under the hood was ridiculous. Since the install I am running constantly right below 210 degrees and have yet to need to turn on the heat to reduce it on the trail.
I give the Poison Spyder Hood Louver :2thumbsup:
Awesome 01-13-2013 03:18 PM
Did you ever put the fan shroud back on?
Carlos14 01-13-2013 09:16 PM
I never had one. I did get one from a friend for a tj but it doesn't fit.
DTS 01-14-2013 09:40 AM
Nice job Carlos! Thanks for the write-up!
Carlos14 01-14-2013 09:43 AM
Thank you! I'm a fan of your guys work, hopefully I can help make others a fan as well:2thumbsup:
TJDaveX 01-14-2013 11:27 AM
Excellent! Looks great. I will be buying one soon. It gets pretty hot here in the summer.
Anticanman 01-14-2013 01:05 PM
Looks great!! Nice write up!!
Carlos14 01-14-2013 01:15 PM
Thanks, it definitely helps on the trails when there isn't any air flowing through the engine compartment. :2thumbsup:
And thanks Canman, I snuck your name in there too :highfive:
Ripper3494 01-14-2013 02:23 PM
soon.....
Carlos14 01-14-2013 07:18 PM
If anyone has one on their own rig post up pics.
Anticanman 01-14-2013 09:08 PM
Haven't taken any shots specifically to highlight it but this one kind of shows it. It's new on the list of mods so not too many pics.
http://i899.photobucket.com/albums/a...126E52ECC2.jpg
KMD 01-14-2013 09:28 PM
I'm digging the shop in the background.
Carlos Looks Great.
The time now is 08:57 PM.
