plastic fuel tank - JeepForum.com
post #1 of 5 Old 10-19-2013, 05:48 PM Thread Starter
jbrackin
plastic fuel tank
just got back from the jeep jamboree in French lick IN, great time! while cleaning the jk, I discovered my fuel tank skid was now malformed and is pushing 2 inches into the fuel tank. obviously I need to upgrade the skid plat. question is my tank now holds 1 gallon less, is there any way to repair the tank or am I buying a new one?
jbrackin is offline
post #2 of 5 Old 10-20-2013, 09:07 AM
biffgnar
biffgnar's Avatar
You could drain the tank and try to press it back out from the inside, but personally that seems like more trouble than its worth. I punched in the dimple on an aftermarket skid plate which did the same to my tank. I just fixed the skid and have been using it. It's possible that the weight of a full tank of gas over time will restore the plastic tank to its original shape. Next time I have the tank down I'll check but not something I worry about.
Romney in 2020!
biffgnar is online now
post #3 of 5 Old 10-25-2013, 10:57 AM
mdm
Farm Wheeler
When I replaced my bashed skid the tank returned to its proper shape.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 5 Old 10-25-2013, 11:36 AM
222Doc
222Doc's Avatar
mine looks like train wreck so does the cross member. I will move the tank before I put a heaver skid. If not for our Government the tank would not be were it is. the thing hangs down below frame by what 3". saving for a Gen right Jk tank that puts it in the back and then I will Flat belly this JK and gain the 3" under the jeep. Just need the $$$$
222Doc is online now
post #5 of 5 Old 10-25-2013, 02:52 PM
Tdog
Dented mine and never knew how but couldn't access dent so it holds a little less. Have skid plate now.
Tdog is offline
