-   General Jeep & Off-Road Equipment (http://www.jeepforum.com/forum/f27/)
-   -   plastic fuel tank (http://www.jeepforum.com/forum/f27/plastic-fuel-tank-1701434/)
jbrackin 10-19-2013 04:48 PM
plastic fuel tank
just got back from the jeep jamboree in French lick IN, great time! while cleaning the jk, I discovered my fuel tank skid was now malformed and is pushing 2 inches into the fuel tank. obviously I need to upgrade the skid plat. question is my tank now holds 1 gallon less, is there any way to repair the tank or am I buying a new one?
biffgnar 10-20-2013 08:07 AM
22 Attachment(s)
You could drain the tank and try to press it back out from the inside, but personally that seems like more trouble than its worth. I punched in the dimple on an aftermarket skid plate which did the same to my tank. I just fixed the skid and have been using it. It's possible that the weight of a full tank of gas over time will restore the plastic tank to its original shape. Next time I have the tank down I'll check but not something I worry about.
mdm 10-25-2013 09:57 AM
When I replaced my bashed skid the tank returned to its proper shape.
222Doc 10-25-2013 10:36 AM
mine looks like train wreck so does the cross member. I will move the tank before I put a heaver skid. If not for our Government the tank would not be were it is. the thing hangs down below frame by what 3". saving for a Gen right Jk tank that puts it in the back and then I will Flat belly this JK and gain the 3" under the jeep. Just need the $$$$
Tdog 10-25-2013 01:52 PM
Dented mine and never knew how but couldn't access dent so it holds a little less. Have skid plate now.
The time now is 08:11 PM.
