painting rusty/metal bumpers - JeepForum.com
post #1 of 14 Old 05-08-2006, 08:21 PM Thread Starter
Jeepin'J
i'm looking to repaint my bumpers, they are metal, i think steel, and have some rust spots on them.
what do i do about the rust if i have to?
what do i do about the sanding if i have to?
what paint do i use?
what order should i do the previous in.
any help would be greatly appreciated.
Jeepin'J is offline
post #2 of 14 Old 05-08-2006, 09:19 PM
TellyDSP
Poland and PPV!!!!
I just did a "new" rear bumper I picked up. I took a sanding wheel designed for removing paint/rust to the rough spots, and it cleaned it up nicely. Then I threw down some rattle can primer and finshed it off with a can of duplicolor bedliner. Turned out nice, and seems like a solid finish. Be sure not to do the duplicolor over an aftermarket paint. It did fine on the primer, but bubbled on the semi-gloss I put on the hitch.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 14 Old 05-08-2006, 09:55 PM Thread Starter
Jeepin'J
thanks for help, but what is duplicolor bedliner?
Jeepin'J is offline
post #4 of 14 Old 05-09-2006, 07:09 AM
lambar
This maybe too expensive, but I have been looking at the Por 15 products to take care of some rust problems that I have on my Jeep. I don't know how well it works on bumpers, maybe someone else can chime in. sorry
http://www.stoprust.net/shop/
1996 GC Limited 5.2L
2" Coil Spacer
30" General Grabbers
lambar is offline
post #5 of 14 Old 05-09-2006, 07:21 AM
TellyDSP
Poland and PPV!!!!
it's just a generic bedliner. Like a Rhino Liner Bedliner, but comes in a spray can for $7. I figured if it doesn't work, it was only 7 bucks. but if it's meant to be a bedliner and see some abuse, I tihnk it'll be fine on my bumper.
POR15 is good for rust and supposed to be rockhard, but I think it's a bit much for a bumper. If you got the coin, go for it. I decided to go the rattlecan direction.
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #6 of 14 Old 05-09-2006, 09:27 AM
bokey
I assume it is just surface rust? If so do it the correct way the first time; you will thank yourself in the long run.
1. First remote all dirt, loose particles etc. from the bumpter. Just give it a good
washing.
2. Next start to sand the bumper with some 200 grit sand paper.
3. Then start to sand w/ 400 grit
4. Then start to <b>wet</b> sand w/ 600 grit
5. Then start to <b>wet</b> sand w/ 1000 grit
6. Next I would lay down an anti-rust primer (http://paint-and-supplies.hardwarest...er-264549.aspx)
7. Personally, I would wet sand it one more time w/ some 1000 grit but you don't
really have to.
8. Lastly apply many <b>LIGHT AND THIN</b> coats of whatever your paiting
your bumper with
This is the right way to do it, and the paint won't begin to flake off etc. after a month. I hope this helps! If you have an questions feel free to PM me.
'94 Wrangler - Traded
'87 Trans Am - SOLD
'99 Cherokee Classic
bokey is offline
post #7 of 14 Old 05-09-2006, 09:36 AM
engus
washing.
really have to.
your bumper with
Can this same process be used to paint chrome bumpers?
4.0L 5Spd Patriot Blue TJ X
31x10.5 Destination A/T
BDS 2" coil spring lift
engus is offline
post #8 of 14 Old 05-09-2006, 09:44 AM
bokey
well chrome is a a real PITA. I personally have not had any experience with painting chrome (since I do like some chrome). Google it to see if you can find anything.
'87 Trans Am - SOLD
bokey is offline
post #9 of 14 Old 05-09-2006, 10:03 AM
bokey
http://www.jeepforum.com/forum/f27/chrome-black-bumpers-264980/
'87 Trans Am - SOLD
bokey is offline
post #10 of 14 Old 05-20-2006, 11:25 AM
blue1989yj
blue1989yj's Avatar
Lambar, Por 15 is great stuff. I have used it in my tub before Herculining, also on Frame Rails, and Spare Tire Mount. It is worth every penny. I just ordered more for other miscellaneous applications.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #11 of 14 Old 05-21-2006, 06:03 PM
wwhitby
1979 CJ5
Don't forget, POR-15 needs a topcoat on top of it so that it won't fade due to UV light. If its in areas that don't see the sun, you don't have to topcoat it.
Warren
Warren Whitby
1979 CJ-5 "Big Blue"
Real Jeeps have rust
Just Empty Every Pocket
wwhitby is offline
post #12 of 14 Old 05-21-2006, 06:17 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
POR 15 doesn't adhere very well to painted surfaces. Need to try and take as much of it down to bare metal as possible. If the rust isn't too bad, you can shoot it with muriatic acid and the acid will eat the rust away. It'll also etch the steel for paint adhesion. If the bumper is painted, I would probably just scuff the paint, run a flap disk (in a grinder) over the rusty parts, and then shoot POR 15 Chassis Black over it (2-3 good coats). That should work out pretty well.
BESRK is offline
post #13 of 14 Old 05-24-2006, 01:59 PM
mascmatt
On the hunt
mascmatt's Avatar
2014 JK Wrangler
I posted the same thread a while ago and somebody recommended Krylon hammer paint. I think thats what it is called. It has "hammer" in the title. He said it works great. I havn't used it yet though. I'll look for the thread.
Found it. Rustoleum, not krylon.
Originally Posted by 05darkness
Just a thought, i used this stuff by Rustoleum called hammer finish paint and it just brushes on, or you can get the rattle can version at any hardware store. It gives a nice looking finish thats real unique and doesnt even look brushed on. Plus i put it on my rocker guards after i had them fabbed and it wont fade, crack or chip and its a rust inhibitor. Looks mean i get compliments on it all the time with people wondering what i used because it looks so good.
Just a thought
mascmatt is offline
post #14 of 14 Old 05-24-2006, 02:07 PM
gunthagunth
gunthagunth's Avatar
anyone used the muriatic trick before. i have like 10 gallons of it and i need to do my steel bumper. anyone know if it will touch rubber or anything to look out for. i use it to acid etch floors now and then for bonding. never thought about using it to etch metal tho.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
Painting Bumpers and Trim XJsport00 General Jeep & Off-Road Equipment 0 07-02-2008 01:45 PM
painting part of hood and metal fenders Negative6 General Jeep & Off-Road Equipment 3 03-10-2008 10:50 PM
Painting a Fiberglass/Metal CJ kbazurpe General Jeep & Off-Road Equipment 11 02-09-2008 02:25 PM
Painting bumpers??? christrx450 General Jeep & Off-Road Equipment 3 09-10-2007 10:17 AM
When painting bumpers BlackFly General Jeep & Off-Road Equipment 4 09-11-2006 02:27 PM
