Painting Procedure - JeepForum.com
post #1 of 14 Old 02-22-2008, 07:57 PM Thread Starter
kirkhbauer
Painting Procedure
getting ready to paint but need some advise. Going to paint Gun Metal Gray metalic. is it best to paint everything at one time or can I split it up , tub first then doors, hood, fenders etc sepertaly? painting myself in a small space. By doing so is there going to be a problem matching the panels? I will most likely buy a gallon of paint so it will be all the same Batch. Will there be any problems with this? Thanks everyone
kirkhbauer is offline
post #2 of 14 Old 02-22-2008, 08:55 PM
turpehar
1977 CJ5
Here are your variables
1. Temperature
2. Humidity
3. Air pressure at the compressor tank
4. Air pressure at the fluid tip
5. Accuracy in mixing each batch
6. Reducer speed
There are others I won't get into.
To answer your question based on my 20 years of experience, I would suggest trying to do everything at one time. This is key. If you paint the tub today and then the fenders and hood tomorrow, those variables can play hell on the outcome. Why? In metallice paint, air pressure and technigue is everything.
turpehar is offline
post #3 of 14 Old 02-22-2008, 09:49 PM
goatboy
Turpehar is absolutely correct...I painted my Jeep piece by piece roughly the same color as you're suggesting...doesn't EVEN match! One of the reasons he didn't get into was that I painted the tub and fenders and hood at their normal angle...and the doors horizontally...and the doors don't EVEN match! But, I don't care...it's a Jeep...if it was my Camaro ragtop, I would have repainted it...If you want it to match, even out of the same can, paint it all at the same time, and use a proper booth...rent one...worth the money...
goatboy is offline
post #4 of 14 Old 02-22-2008, 10:45 PM Thread Starter
kirkhbauer
Thanks guys might have to go to Macco and have them spray it. Suppose if im willing to spend money on Dupont better not try this one on my own. Problem is closest Macco is 4 hours away
post #5 of 14 Old 02-22-2008, 11:10 PM
Ja$onMagnum
I wouldnt go to maaco if I were you. Im not sure if its the same by you as it is by me, but they do pretty half hearted work. They give cheap prices because they use cheap paint and do a pretty sloppy job. If you're not looking for a show quality job, go there. I wouldn't recommend it though.
Ja$onMagnum is offline
post #6 of 14 Old 02-23-2008, 01:55 PM
goatboy
Yer on the right track, though...by the time you buy the compressor (and a small one won't do) gun, yadayadayada and materials, you will have spent more money and time than it is worth...and if it's yer first paint job, you probably won't be particularly happy with it!
goatboy is offline
post #7 of 14 Old 02-24-2008, 07:56 PM
81CJUSMC
1981 CJ7
Well, If you did decide to paint yourself, being that I have a decent compressor and a gun, what would be the best possible situation for DIY to set up in my garage? I understand I would have to allow for ventilation, but anything I might not be thinking about?
Jason
If it's that important to do on a Friday, it can wait until Monday...
81CJUSMC is offline
post #8 of 14 Old 02-24-2008, 10:02 PM
goatboy
Turn off the water heater.
goatboy is offline
post #9 of 14 Old 02-24-2008, 10:32 PM
BWR
Amen to that. But actually ANY ignition source for that matter: if you have an electrical fuse box in the garage...well, you'll *probably* be safe...but I'd bag it, tape it off, whatever.........
to which I'll add for the other small inconviences....
Also COVER EVERYTHING...I mean EVERYTHING in the garage: better yet, drape off a section of the garage like a cave/box for the whole painting....that would include the floor. Nothing like random dust to ruin an otherwise good spray. If you dont want to do the floor then WASH down the floor and air spray it outta the garage.
DO use the tackcloth...actually use several.
Take the time to tape everything off.....its a PITA BIG TIME but its small stuff like this that shows the experts from the 1st timers.
BWR is offline
post #10 of 14 Old 02-25-2008, 06:35 AM
aero mech
aero mech's Avatar
1980 CJ7
Kirk, to give you a for instance, my dad and I painted his silver cj5 in pieces in my shop, He even painted the hood and grille outside the front door. Goatboy and the others are right about metallic paint. The grille and windshield frame look alot differnt than the rest of the jeep. He didn't worry about it though it is a jeep. I will say this from what I have seen metallic paint is much harder to spray. We had to respray the hood due to tiger stripping. We did find with two people, one painting and one mixing and keeping the batch stirred up really well the panels will be very close. I am currently primming my 7 in the same shop and plan on shooting things seperatly but with viper red and no metallic. Good luck jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #11 of 14 Old 02-25-2008, 07:36 PM
sideways
Kirk, are you using single stage or basecoat/clearcoat?
If using basecoat/clearcoat, you can base one part, let it flash, move it, then move another panel in base it etc...
If using single stage you are better off painting everything at once
sideways is offline
post #12 of 14 Old 02-26-2008, 09:00 PM Thread Starter
kirkhbauer
was planing on Dupont 6000 base coat and then clear
post #13 of 14 Old 02-26-2008, 10:01 PM
goatboy
Tigerstriping could be the function of a lower quality paint gun, or spraying too close to the surface...what I like to do with metallics, even though I use top grade guns and don't have problems with 'em, is right after I spray a panel or area, spray a dust coat over the whole thing from at least 2-3' away from the surface...
goatboy is offline
post #14 of 14 Old 02-26-2008, 10:13 PM
Gunkel
Gunkel's Avatar
x2 what goatboy said, a "drop-coat" is your friend!
Gunkel is offline
Radiator Replacement Procedure on my 93 XJ shelbydodge Engines & Drivetrain 1 04-15-2009 09:48 PM
Procedure for putting in/taking out TB? Jeff9 Street Jeep Forum 3 01-12-2008 04:34 PM
new gear break in procedure question EMT Engines & Drivetrain 2 09-16-2006 07:57 PM
Post winch-dunking procedure MuddyV8YJ General Jeep & Off-Road Equipment 4 04-14-2004 03:49 PM
New 258' Break in procedure, help? mde Engines & Drivetrain 3 12-21-2003 10:46 PM
