Painting jeep hardtop - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Painting jeep hardtop
Engo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air lockerIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-29-2008, 07:48 PM   #1
joe's_yj
I know this has been beaten to death but im thinking of spraying my hardtop black tomorrow. i was thinking of using the same paint i painted the jeep with, valspar tractor enamel gloss black. will the gloss look bad?
my build up http://jeepforum.com/forum/showthread.php?t=427353
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline   Reply With Quote
Unread 08-29-2008, 08:43 PM   #2
CopperCJ7
Have you thought about using Herculiner or Durabak?
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline   Reply With Quote
Unread 08-29-2008, 08:53 PM   #3
benefitsguy
I used Krylon Fusion. Cleaned the hardtop. Acetone and then a tack cloth. Took three cans and it looks almost like my wife's hardtop for her JK. Used a satin finish if I remember right.
Mine - 05 LJ Rubicon, Black, 3.5 RE, 6cyl 4.0L, NSG 370: manual six-speed, LT285-75R16
Daughter's - 1997 TJ Sport, White, 6cyl 4.0L, manual 5 speed - stock
Son's - 1992 XJ, White. 6cyl 4.0L, auto, 3" Rusty's Lift, 31x10.5x15
RIP - 93 YJ Hot Pink - 6cyl 4.0L AX-15, 3.5 BDS Lift, 32x11.50x15
benefitsguy is offline   Reply With Quote
Unread 08-29-2008, 09:11 PM   #4
joe's_yj
you just do light coats with the krylon? when ever i spary black paint you can always see the spray lines
Unread 08-29-2008, 09:16 PM   #5
benefitsguy
Yeah, light coats. I definitely took my time and didn't rush it. Bought one of those trigger sprayers for the spray can and spent the day in the paint booth (garage).
Unread 08-29-2008, 09:29 PM   #6
joe's_yj
alright, i got the trigger and a garage, ill give that a shot. what did you do for prep?
Unread 08-29-2008, 09:40 PM   #7
benefitsguy
If memory serves me,
I cleaned the hardtop and dried it real well.
Lightly sanded it with a scotch brite pad. It was a brown one from AutoZone in their paint department.
Blew the dust off with my air compressor.
Let it sit for a while in the garage to settle and dust.
Used a tack cloth (AutoZone as well) all over it.
Masked the glass with green tape and newspaper.
Used a second tack cloth where my hands may have touched the hard top.
Started spraying the top and and then sides like you would with a paint gun.
Lots of strokes releasing the trigger while still using a spraying motion. (Followed the instructions on the can regarding drying times.)
Repeated until I went through three cans of Krylon.
Take your time and be sure to prep.
Unread 08-29-2008, 09:46 PM   #8
benefitsguy
If you do a search of the forum, goatboy had a write up that talked about painting a hardtop. I used most of his write up for painting my hardtop. My hardtop didn't require any fiberglass repair which probably saved me.
