Only starts with a jump - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Only starts with a jump
50" LED CREE Light Bar Pair With Wiring KitBorla Exhaust presents "Climber" at EJSTactical Recovery Equipment Soft Shackles!!!
Unread 05-27-2013, 09:15 AM   #1
smokefist
New battery, turn key to on there's a pause then power, try to start nothing...goes dead...but will start with a jump
Any suggestions? Ignition switch? Starter?
smokefist is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 09:22 AM   #2
mylt1
clean and tighten the battery connectors.
mylt1 is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 09:24 AM   #3
smokefist
Did that first with the old battery
Unread 05-27-2013, 09:29 AM   #4
B52dude
Mine did the same thing a while back. Replaced the battery cables and it was good to go. Depending on how old it is, you may not see any corrosion from the outside, but have barely any wire left on the inside.
[QUOTE=Ripper3494;10936705]i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol[/QUOTE]
Red Jeep Club #614
B52dude is offline   Reply With Quote Quick reply to this message
Unread 05-27-2013, 09:38 AM   #5
wilson1010
When you say "jump" do you mean two cables hooked to another car's batter and clipped to the battery cables still attached to your battery terminals on your rig? If so, not battery cables, not starter or ignition switch. A volt is a volt is a volt.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406
wilson1010 is online now   Reply With Quote Quick reply to this message
Unread 05-27-2013, 09:39 AM   #6
smokefist
Yes my cables attached to my battery and jumper cables to another car
Unread 05-27-2013, 09:44 AM   #7
wilson1010
So, electricity runs from another car to your battery cables, still attached to you battery terminals. That means the only difference in the circuit is your battery. I know you have a new battery, but there is no other explanation.
Remove your battery cables from the terminals on the new battery, hook up the jumper cables to your rig's cables (now detached from your battery) just to confirm the circuit.
Unread 05-27-2013, 09:51 AM   #8
smokefist
Disconnected my cables, ran jumper cables from car to just my cables and started right up...brand new battery though
Unread 05-27-2013, 09:56 AM   #9
wilson1010
You can see it with your own eyes though. right?
Nothing different than the battery and even that jump battery has less power due to the cables.
Now, just to be sure, hook the jumper cables to your battery, then to your cables (which are still removed from the terminals). That will tell you if your battery is bad or the cable/terminal contact is defective.
Unread 05-27-2013, 10:06 AM   #10
smokefist
Took my battery completely out hooked cables to it and my rig...just a click then no power, then hooked cables to a running car to jump it and got the same thing this time...just a click then no power
Unread 05-27-2013, 10:17 AM   #11
wilson1010
Was the other car running when you jumped it successfully before?
Unread 11-28-2013, 05:24 PM   #12
gott
I have a 93 Jeep g c lerado that only wants to start with a jump any ideas
gott is offline   Reply With Quote Quick reply to this message
Unread 11-29-2013, 02:11 AM   #13
wilson1010
Yea, if it starts with a jump then everything is working except the battery or the cable attachments. Start by removing the cables and wire brushing the terminals, cable ends and reattach.
Next, fully charge the battery with a battery charger.
Still no start, your next trip is to Pep Boys for a new battery.
Unread 12-01-2013, 09:11 AM   #14
rjbruzan
Did you clean the terminal shiney bright clean and tighten the terminals with a wrench? If you did the battery is bad.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline   Reply With Quote Quick reply to this message
