off-road trailer to tow behind my ZJ
#16 | |||
zj tractor
hard working private first class in the United States Marine Corps. Quote:
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/ |
#17 | |
zj tractor
here are some under side pics.
#18 |
Why'd you use a 8.8? Why not use a non-drive axle from a 2wd vehicle....you'd have a higher ground clearance.
#19 |
Nice looking trailer andy, looks fun to jump on.
You have your engine running in the garage without the door open? |
#20 |
a rear sway bar will keep it from rocking
#21 |
it would also cut down on the weight. not like it matters though because the thing almost weighs as much as his jeep. he overbuilt it so much you could probably transport an small aircraft on it...
#22 |
What if he is wheeling one day and finds a small aircraft crashed on the trail and the guy is alive and needs to go to the hospital but won't go without his plane. Then what... Ok that is ridiculous in every way.
#23 | ||
zj tractor
so will shocks.... who ever heard of a sway bar on a off-road trailer anyway?? you say that like it is a bad thing.
#24 |
You could put a tool box on that front part right after the hitch and before the trailer bed starts. That might be handy. Just an idea.
#25 | ||
zj tractor
#26 |
Dang that will be sweet. Looks good.
#27 | |
zj tractor
thanks, i need to finish the jeep, and get some more money so i can spend some on the trailer.
#28 |
I seen the mud flap part , but you should check to see if you need fenders, also.
.... them coppers just love a reason to give tickets...
94 Grand Cherokee ... 332,000 miles 5.2 liter 242 :) Rancho 5000 steering stabilizer |
#29 |
he has fenders...
#30 | |
zj tractor
it will not need fenders, i actualy work at the PD, so im prety good about knowing what i can and cant get away with.
im supriesd some one nocied them.... the one on the passenger side needs to be cut off and re-welded, it tilts down a little. not gona use the flares..... gona go with the mud flaps.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
