Had a piston seize up on a caliper last Feb.
Replaced it with a box store caliper so I could get to work. Didn't replace the rotor as it wasn't worn badly. Caught the caliper issue looking for another issue.
Ever since, I've noticed the outboard side of the caliper is only wearing on inner edge and the inboard side is only wearing on the outer edge.
The I've measured the rotor with brake rotor calipers and the sides are parallel, although that doesn't mean they are square to the caliper. I have no od brake symptoms and the it doesn't pull one way or the other when braking.
Anyone have any idea what's going on?
